Wayne Phillips
- Jan 7, 2018
- 61
- Joined
- Jan 7, 2018
- Messages
- 61
I was asked by the local welder to look at his migwelder as the wire feed motor and the control board was acting up.
1) when trigger was pressed in, it's wire feed circuit board could be heard working.
2) you had to adjust the control all the way round before the wire would feed out.
So, off with the covers and on show are two large bulky power transfirmers and a small feed board.
I tested the 24v dc wire feed motor with a power pack and all good there, so time to remove the control pcb and try a few things out.
Chagned the 470k adjuster pot followed by some old caps and give the pcb a good cleaning. After fitting the pcb in it still was only half working and pointing to the c mos smd chip.
My phone call to the welding tech shop was less that helpful and in there word's
"We poke and probe till something works"
Must be a new tech sort of term poke/ probe..
In the end I did order a new pcb at £130 qid and I did not wanted to spent to long on this unit.
I still have the old wire speed pcb..
Still all working now.!!!
