Microphones vs. ear sensitivity
K
Kryten
Hi all.
Just been playing with some cheap (ECM-66B) microphone inserts and found
they have a pretty poor performance compared with the human ear. I can hear
some very quiet sounds in my room: the ticking of my clock and distant
barking dog. This sensor can pick up sounds at this level but when the
signal is amplified enough to hear them, there is a lot of noise with it.
The S/N ratio is quoted at 40 dB, and sensitivity at 60 dB/microbar.
It seems okay where it is next to or nearby a person's mouth, like a hand
held microphone or a telephone. But if you stuck a pair on a dummy head and
listened through an amplifier, you would not get a good sense of being in
the room.
So, do microphones get much better than this?
Or is the ear such a marvellous organ that it is yet to be beaten?
P
Pooh Bear
Kryten said:
Hi all.
In short, it's rubbish.
the room.
Professional condensor mics are often specified in terms of their dBA
equivalent noise. I haven't heard of one lower than 12 dBA.
It is.
Graham
James Meyer
It is.
Graham
Of course, the ear is supported by quite a bit of additional signal
processing. If you looked at the nerve signals between the ear and the brain, I
suspect that any useable information is thououghly buried in the "noise".
Jim
P
Pooh Bear
The way the ear hears is not exactly understood. The fact that it can apparently
'outperform' test instrumentation in critical istening tests in certain tests but
not others perhaps adds to that puzzle.
Note that the ear hears partly by means of many cilia that are quite high Q 'tuned
circuits'. I can't imagine a simple model of how humans or other animals hear. For
example the ear can extract a signal that's 'buried in the noise' if it's of narrow
enough bandwidth.
Graham
P
Paul Hovnanian P.E.
Kryten said:
Hi all.
the room.
Yes. Microphones designed for close in work (telephones, handheld voice
mics, etc.) are not very good for picking up weaker or more distant
sounds. They are made intentionally insensitive so as not to be
overdriven by close in sources.
The ear is pretty good, but being attached to the human body, it comes
with its own noise sources. In a very quiet environment, my breathing
and heartbeat drown out sounds that could be picked up by a sensitive
microphone.
B
Ban
It is.
Graham
I do not know if it is true but this mike from Bruel and Kjaer has extremly
low noise:
The model 4179 is claimed to have -5.5dB(A) thermal noise only, that would
be more sensitive than the human ear. http://www.bksv.com/3035.asp
Neumann has one with +7dB(A)
http://www.neumann.com/infopool/mics/produkte.php?ProdID=tlm103&Language=Engl
and another one: BCM104
They also have a mike with built-in DSP with the same sensitivity.
http://www.neumann.com/infopool/mics/produkte_sol_d.php?ProdID=solution-d&Language=Engl
K
Kevin Aylward
We can't beat the brain that processes the ear information, but as far
as the ear itself goes, just what can it detect that test equipment
cant?
apparently 'outperform' test instrumentation in critical istening
Oh?
Care to support this with some references?
but not others perhaps adds to that puzzle.
You must be using duff test equipment. I dont see that there is anything
the ear/brain can hear that decent equipment can't measure. We just
don't know what the measurements mean.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
K
Kryten
I didn't expect much for my £2. :)
The dynamic range is certainly poor, but adequate for some applications.
It is sensitive enough it can pick up feint sounds, only buried in noise.
I was surprised by the amount of difference a simple plastic funnel made.
Pointed out the window at a bunch of trees, the birdsong from them was much
louder.
Might be fun to play with a parabolic microphone :)
How much does a reasonable quality transducer cost?
I've seen mikes for several 10s of £, but much of that cost must go to make
the robust housing for the transducer.
microphone.
I suspect it has noise cancelling mechanisms.
After all, it is buried in a mass of blood vessels and right next to
airways.
As an aside, what is the noise heard when a sea shell is held to the ear?
Usually explained as air currents, I find that hard to believe.
I guess it is sounds coming from the head/ear itself, resonating and
reflected back into the ear.
R
René
Hi all.
the room.
FWIW, I once built a remote microphone for my handycam, incorporating
a junkbox electret, a BC547 (as "frontend"), a 4558 (one half used) -
to create a AGC mike amp with line level out (9V battery fed). The
thing could "hear" things that I could ony detect with my "bare" (then
still quite good) ears after noticing it on the headset. It would even
feedback over thesound leaked out of the earphones.
In other words, I guess that with sufficient power line filtering and
an adequate gain distribution - it may not be that bad.
K
Kryten
a junkbox electret, a BC547 (as "front-end")
Yep, I did that (BC550 replacing BC547) and used a CA3140 op-amp.
I have a VOGAD (voice-operated gain adjustment) chip somewhere I will try
out.
It would even
feedback over the sound leaked out of the earphones.
Yep, noticed that too.
I think the electronics are fine, so the electret is the noisy bit.
Recently heard of the "microflown", which is a silicon micromachine that
senses the flow of air instead of pressure. Since it is very small
(<match-head) and low-mass I suspect it may be a lot more sensitive. However
I can't see anywhere selling them off the shelf. The manufacturers are
selling for novel applications.
http://www.microflown.com/
Z
Zak
Try it with a satellite dish... the nice thing is that your microphone
will point up and not cacth much ground noise while the reflector
determines to which piece of ground you listen.
Thomas
M
Mark
out.
most electret elements have an FET preamp built in so this bit of
electronics may be adding some noise.
Mark
K
Kryten
so this bit of electronics may be adding some noise.
Yes, I'm just surprised that one FET can add so much noise.
What technology do decent quality microphones use?
P
Pooh Bear
Cheap fets I expect !
Professional conndenser mics use larger capsules and polarising voltages
that produce more output for the same SPL. Hence the s/n is better. And
they use quiet fets ( or toobs even in very old ones ! ).
Graham
P
Pooh Bear
low noise:
It's a larger than average capsule ( see diameter ) which helps but even so that's an
astonishingly low noise figure. Looking at the data it has a polarising voltage of 200V.
That helps too.
Not too surpised at Neumann. Good products. I was thinking of more affordable mics !
I once owned an Neumann U87 - a classic mic. Last time I checked the RSP was £1600.
Graham
K
Kryten
Professional condenser mics use larger capsules and polarising voltages
they use quiet FETs ( or toobs even in very old ones ! ).
Okay, that makes sense.
If the bias voltage is 20 times my 9V battery,
signal should be 20 times greater.
And that will be roughly multiplied by the area increase.
Hmm... I'm tempted to see what kind of output I'd get from two sheets of
tinfoil (say 30 x 30 cm)held under tension very close to each other? Not the
most practical stage mike, but it does provide a large sensing area. I
imagine it would be pretty directional too.
P
Pooh Bear
Tried something like that using metallised melinex once as an experiment to make
an electrostatic speaker.
I can see why it's best left to the experts !
Graham
K
Kryten
to make
Ah, but that is trying to put sound out, rather than sense sound in.
AFAICT the change in C needs to be as big a fraction of the total C for best
results.
Thus the sheets need to be close as possible.
I think that is the hardest bit.
K
Kryten
Pooh Bear said:
Okay, it is pretty small so not got a great sensing area.
And for £3 I did not expect much.
I went out and bought a dynamic mic insert for £5, and this is labelled as
having 76 dB sensitivity. It is a lot bigger and heavier.
http://www.maplin.co.uk/Module.aspx?ModuleNo=29594 (type DM13)
I made up this preamplifier
http://www.zen22142.zen.co.uk/Circuits/Audio/dyn_mic/dyn_mic.htm
which is all-discrete so should have low noise.
However I didn't find it was much improvement.
There is noticeable hiss and buzz.
Hiss seems to be coming from the first transistor (BC109, common base) and
the buzz from the mic insert, because the buzz disappears when the signal
input is shorted to ground. The hiss and buzz disappears when there is no
signal to the other transistors.
Circuit constructed on a bit of veroboard - not ideal but fairly neat and
compact.
So, is this mic insert also crap, and if so how much would I expect to pay
for a good one?
Also, is this BC109 transistor just too noisy?
Or am I going to have to make a much more complex pre-amp like this one:
http://sound.westhost.com/project66.htm
R
René
compact.
for a good one?
Cleaning the power line (1K - 220 uF, that sort of thing), may help
tremendously. Batteries are noisy! Power supplies more so.
Gain distribution, not too much gain in any stage. e.g. ~20x in the
transistor, same in the opamp. Never let the frontend transistor
amplify flat out (grounded emitter)
As I had the pleasure of commenting before - a junkbox electret /
transistor / low end opamp ckt. easily matched my hearing treshold.
(when I built it -long ago- my hearing was not all that bad actually)
