Regarding 1/4" (and probably also 3.5mm) switched audio jack sockets; which pin of the actual socket corresponds to which pin in the schematic part when it comes to the switch?
And are switched jack sockets standardized in the way that they have 3 pins, the "tip" pin stays at is, while the "sleeve" and the third pin short whenever a jack plug is removed from the socket?
