R
reggie
A rule of thumb I have heard about and want to check its validity is
that:
For a fan cooled forward converter transformer, employing feed forward
should have a flux density lower than 250mT as not to saturate for TDK
PC40.
1) Is this a reasonable estimate of max flux density at say 100 Deg C
100KHz.
I know that in PSU terms (not described accurately mathematically)
V=NdØ /dt
B=Ø/Ae
Thus:
V=N*Ae (dB/dt)
therefore following integration etc...
V *dt = N *Ae * dB
And thus
dB = (V*dt)/N*Ae---(1)
and by similar methods
dB = (L*dI)/N*Ae----(2)
(d indicated change or delta)
2) For a continuous forward converter, would this 250mT = (dB) limit
be as a result of
a) the ripple current peak to peak in the coil (from low value to high
value of the trapezoid) during the fet on time = (dT) or
b) the max current (from zero to the top of the trapezoid) during the
fet on time = (dT)
I think a)
Have I the wrong idea?
Reggie,
that:
PC40.
100KHz.
V=NdØ /dt
B=Ø/Ae
Thus:
V=N*Ae (dB/dt)
V *dt = N *Ae * dB
And thus
be as a result of
fet on time = (dT)
I think a)
Reggie,
