S
Spehro Pefhany
Yeah, but that uses transistors.
John
Something like this?
http://www.google.com/patents?id=2p1tAAAAEBAJ&printsec=abstract&zoom=4&dq=3317749#PPA1966,M1
Best regards,
Spehro Pefhany
John
hi all,
I want to know the advantages of edge triggered flip flop over master-
slave flip flop.
Please let me know this.
thanks in advance.
<Smirk>
Except an "edge-triggered" flip-flop IS "master-slave".
Jim Thompson said:<Smirk>
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona 85048 Skype: Contacts Only | |
| Voice480)460-2350 Fax: Available upon request | Brass Rat |
| E-mail Icon at http://www.analog-innovations.com | 1962 |
America: Land of the Free, Because of the Brave
Huh? Please post a schematic of an edge-triggered flip-flop. I'll
make it easy on you... you are allowed to use a PECL/ECL configuration
http://www.learn-c.com/74ls74.pdfHuh? Please post a schematic of an edge-triggered flip-flop. I'll make
it easy on you... you are allowed to use a PECL/ECL configuration ;-)
Jim Thompson said:That's similar to what I was referring to, from the '60's.
See...
http://analog-innovations.com/SED/ToggleFlopAncient.pdf
John Larkin said:No. Not all edge-triggered flipflops have the master-slave
architecture. And not all master-slave flops are edge-triggered; one
could design a m/s level-sensitive transparent latch.
Master-slave is an internal architecture. D, T, JK, RS,
level-sensitive, edge triggered, are all external behaviors.
The DDR flops in Xilinx io blocks are interesting; they have two
edge-sensitive clocks. That must be interesting to implement; it can't
be classic master/slave.
I used to design flipflops that used only resistors, capacitors, and
diodes.
John
To-Email- said:Jim said:On Thu, 29 May 2008 08:52:44 -0700, John Larkin
On Thu, 29 May 2008 08:04:08 -0700, Jim Thompson
[snip]
See...
...Jim Thompson
Speaking of flip-flops, you might enjoy this:
http://www.nypost.com/seven/0529200...ir_cam_erica_guy__arrested_in_guam_112983.htm
John
Delighted!
Hopefully Al Franken's candidacy will be damaged.
Why? I thought he was running for 'The biggest idiot on earth'?
Yes... but only in Minnesota...
