Maintained to momentary switch converter
Discussion in 'General Electronics Discussion' started by Apocalypso, Feb 13, 2018.
  1. Apocalypso
    Apocalypso
    Feb 13, 2018
    3
    I'm just curious if it is possible to get impulse from classic maintained 220v light switch, as a matter of fact I need to convert this toggle light switch to momentary to control impulse relay...
    Thx in advance ;)
    Lp,
    Teo
    #1
  2. Apocalypso
    8,595
    1,663
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    If you need to keep the original switch, you can connect it to the input of a monostable multivibrator to generate a single impulse.
    Otherwise replace teh switch by a momentary switch which is available in the same form factor for exactly this purpose.
    Harald Kapp, Feb 13, 2018
    #2
  3. Apocalypso
    Apocalypso
    Feb 13, 2018
    3
    thx for the quick respond, can U be a little bit more specific? Which kind of multivibrator, any schematic? The problem is that this switch is remotely controlled and I can't replace it momentary switch because momentary isn't available with remote control function and that is my main problem...
    #3
  4. Apocalypso
    AnalogKid
    Jun 10, 2015
    2,208
    623
    Ohio - GMT-5
    It the switch is switching 220 Vac and the impulse relay coil is rated for 220 Vac*and* continuous operation, then you don't need to convert the output from the switch to a momentary signal. What are the manufacturer and part number for the relay?
    ak
    AnalogKid, Feb 13, 2018
    #4
  5. Apocalypso
    Apocalypso
    Feb 13, 2018
    3
    Apocalypso, Feb 14, 2018
    #5
