DavidW said:
The particular product that won't work is an NTSC version of the DVD box set of
Buffy the Vampire Slayer (seven seasons, about 40 DVDs). What pisses me off is
that I don't want to copy them. I only use the VCR as a switching box or
occasionally to play an old tape. I would have thought that the VCR could have
been made so the protection only comes into effect when you actually record
something, not when you are just using it as a pass-through device. I shouldn't
have to re-cable my equipment to get around this crap. Also, I read somewhere
that there are standards for video signals and that Macrovision deliberately
breaches them.
Oh, don't bother with that. I decode the DVD directly. It's much
easier, more flexible and faster than stuffing around with macrovision
boxes.
Kinda like making HDMI entirely pointless. It was *supposed* to stop
people from taking the DVD/blueray stream and passing into a black box
that duplicates elsewhere. They employ a combination of encryption and
security by obscurity to stop people from doing things that way.
Unfortunately for them, since DVD and BlueRay encryption was hacked
within a week of release, thus by-passing the HDMI issue altogether, you
not only get direct access to the raw video stream, you also get menus
as well.
But since this is not what you're after, in your case, an AV switcher
might be a lot easier to deal with. Some smaller simpler units are
available for reasonable prices. It means an extra remote, but a lot
less stress.
I haven't got into torrents at all yet. They sound like a pain. I want to watch
on the TV, not a computer, so I'd somehow have to get the stuff off the PC and
onto a DVD. Then there's finding the shows in the first place, download
problems, download cost, whatever conversions I'd need to do, etc., etc. Much
easier just to buy some DVDs.
I'm the opposite, I've given up and changed the way I do things
altogether. I use a PC and larger monitor with a tuner to replace the
job of the "VCR" and TV of old.
I actually have a file server holding the video files, but within
reason, you can hold the video files on that same PC. So you certainly
don't need the infrastructure and hardware that some of us have.
The added advantage is, most (proper) PC players will play DVDs with
all protection turned off. Getting past FBI warnings is easy as the
skip button, no need to be FORCED to wait for things like that. Nor
previews on some Disney DVDs.
Even better, some video cards have composite or HDMI or similar that
many TVs have, so you don't even have to upgrade your TV to take
advantage. More so, Macrolvision doesn't exist at this composite output
anymore, so you could tape it (if you wanted to).
You *DO* need a PC though.
