Lt spice: Is there a Freq transfer function (table: frequency, transfer, phase)
Discussion in 'CAD' started by Ronald Buining, Feb 21, 2008.
  1. I use Lt spice.
    I want to design an inputfilter for a circuit of which I have:
    - the transfer function (table: frequency, transfer, phase)
    - the input impedance as function of frequency (table: frequency, transfer,
    phase)
    What function can I use in LtSpice to import these tables into the
    simulation. I cannot find a function for it.
    If it is not possible with LtSpice is there a alternative for LtSpice which
    can do this. If needed I can spend up to a few hundred dollars.
    I can understand that it is only possible to simulate ac transfer. That is
    ok. I am interested mainly in simulating the ac transfer function of this
    circuit including the inputfilter.
    Ronald
    #1
    1. Advertisements
  2. Hello Ronald,
    You can either use the classic E- and G-sources with Freq-tables
    and PSPICE syntax or you an use the B-sources from LTspice.
    Bv-source:
    V=V(1,0) MAG FREQ=(1e6, 0.893, -26.7) (2e6, 0.705, -45.2) (5e6,
    0.37, -68.3) (10e6, 0.195, -78.7)
    Bi-source
    I=V(1,0) MAG FREQ=(1e6, 0.893, -26.7) (2e6, 0.705, -45.2) (5e6,
    If you send me your email address, I will send you an example with E and B
    sources.
    You can download this example also from the LTspice Yahoo group.
    http://tech.groups.yahoo.com/group/LTspice/
    Files > Tut > freq_table_E_B_1.asc
    http://tech.groups.yahoo.com/group/LTspice/files/ Tut/
    Best regards,
    Helmut
    Helmut Sennewald, Feb 21, 2008
    #2
    1. Advertisements
