Hi, i'm currently doing a project using LPG Gas Sensor Module (#27932) from parrallax and msp430.
http://www.parallax.com/Store/Senso...ortField/0/Level/a/ProductID/593/Default.aspx
i think i should give u guys some info that i know, TP 3 & 4 is the refrence voltage while TP 1 & 2 changes due to the concentration of the gas. That abt all that i know
i have encounter a few problem while i'm calibrating the gas sensor.
Firstly, i'm calibrating it without any micro-controller(because i dun have 1)(which might lead to my second problem)
Secondly, the voltage between TP 1 and TP 2 should increase when it detect related gas, but for me, it increases even without any gas. So is there anyway to stablize or keep the voltage low between these point.
Thirdly, my friend suggest me to use the attached circuit, i have tired it, the voltage still increases slowly over time, but after it goes pass the refrence voltage, it goes down to 0.016 volt, which is good, but i want it to stay like this when from the start, and not after so long.
sorry if i have confuse some of you with my english, but i really hope that you guys could help, thank in advance. cheers
