hamed tahamtan
- Sep 22, 2017
- 3
- Joined
- Sep 22, 2017
- Messages
- 3
hi guys
I was designed a lpc1768 board for myself but I have some bad and unusual problem with it .
As I assembled the bored I programed it with a jlink segger programmer and it was programmed very well. But when I tried to run the program I understood that the microcontroller didn't work well. in fact the board some times works very well and some times didn't work at all.
I tried to debug the microcontroller with a jtag debugger and keil software and I catch on some problems.
in the file "system_LPC17xx.c" in the line 523 the cpu will stope
the folowing codes are lines that cpu stops at then
LPC_SC->CLKSRCSEL = CLKSRCSEL_Val; /* Select Clock Source for PLL0 */
LPC_SC->PLL0CFG = PLL0CFG_Val; /* configure PLL0 */
LPC_SC->PLL0FEED = 0xAA;
LPC_SC->PLL0FEED = 0x55;
LPC_SC->PLL0CON = 0x01; /* PLL0 Enable */
while (!(LPC_SC->PLL0STAT & (1<<26)));/* Wait for PLOCK0 */
LPC_SC->PLL0CON = 0x03; /* PLL0 Enable & Connect */
while ((LPC_SC->PLL0STAT & ((1<<25) | (1<<24))) != ((1<<25) | (1<<24))); /* Wait for PLLC0_STAT & PLLE0_STAT */
and the error command is coming below
**JLink Warning: CPU could not be halted
***JLink Error: Could not start CPU core. (ErrorCode: -1)
***JLink Error: CPU is not halted
***JLink Error: Can not read register 15 (R15) while CPU is running
***JLink Error: Can not read register 16 (XPSR) while CPU is running
***JLink Error: Can not read register 0 (R0) while CPU is running
***JLink Error: Can not read register 1 (R1) while CPU is running
***JLink Error: Can not read register 2 (R2) while CPU is running
***JLink Error: Can not read register 3 (R3) while CPU is running
***JLink Error: Can not read register 4 (R4) while CPU is running
***JLink Error: Can not read register 5 (R5) while CPU is running
***JLink Error: Can not read register 6 (R6) while CPU is running
***JLink Error: Can not read register 7 (R7) while CPU is running
***JLink Error: Can not read register 8 (R8) while CPU is running
***JLink Error: Can not read register 9 (R9) while CPU is running
***JLink Error: Can not read register 10 (R10) while CPU is running
***JLink Error: Can not read register 11 (R11) while CPU is running
***JLink Error: Can not read register 12 (R12) while CPU is running
***JLink Error: Can not read register 13 (R13) while CPU is running
***JLink Error: Can not read register 14 (R14) while CPU is running
***JLink Error: Can not read register 17 (MSP) while CPU is running
***JLink Error: Can not read register 18 (PSP) while CPU is running
***JLink Error: Can not read register 20 (CFBP) while CPU is running
At first I Thought that it is because of the microcontroller and I changed it , but the problem is still continued.
Now I guess that it should be because of the crystal oscillator but I'm not sure because that some times it works .
thank you for every help
