Low Voltage Li-on battey 18650
Discussion in 'Power Electronics' started by Chan777, Sep 12, 2018.
  1. Chan777
    Chan777
    Feb 20, 2018
    i have 6 cell 18650 from a dead laptop. the four cell have each 2.7 volts, and two have 2.2 volts.. is it possible that 2.7 volts can still be use?
    tnx
    #1
    1. Advertisements
  2. Chan777
    HellasTechn
    Apr 14, 2013
    1,338
    187
    I do not think so... The 18650 are considered full empty at 3.6V and full charged at 4.15~4.20.
    Chances are that those cells are either completely unusable or storage capacity has seriously diminished if they where sitting around at such low voltage for long time.
    In my opinion the best case scenario for you is that your cells have lost most of their capacity to store energy.
    HellasTechn, Sep 12, 2018
    #2
    1. Advertisements
  3. Chan777
    Hopup
    Jul 5, 2015
    185
    22
    Yeah dont try to use them, cells can be dangerous when under minimum voltage.
    Hopup, Sep 12, 2018
    #3
  4. Chan777
    dave9
    Mar 5, 2017
    414
    91
    3.6V is the nominal voltage rating, not full empty which is closer to 3.0V. Many manufacturers specify even lower than that, around 2.x V (2.5V, etc).
    If you can determine the manufacturer then get the datasheet to see the minimum safe discharge voltage they specify. The 2.7V cells are "probably" fine, and the 2.2V more likely not fine, but I would put them in a charger inside a metal container or away from anything flammable like on a concrete floor for the first few charge cycles to see if they're behaving normally.
    dave9, Sep 12, 2018
    #4
  5. Chan777
    HellasTechn
    Apr 14, 2013
    1,338
    187
    I agree with what you say but still i would not use them.
    We are missing a key factor here. How long have they been sitting arround like that ?
    HellasTechn, Sep 13, 2018
    #5
  6. Chan777
    Chan777
    Feb 20, 2018
    about a year and a half on my broken laptop
    Chan777, Sep 14, 2018
    #6
  7. Chan777
    HellasTechn
    Apr 14, 2013
    1,338
    187
    I would not trust them.
    Still you can charge them up to about 4,18V and put them to use. thay may still be ok for a flashlight or something like that but dont expect too much.
    Make sure you use a good quality 18650 LiPo battery charger. These cells can explode if overcharged.
    HellasTechn, Sep 15, 2018
    #7
    1. Advertisements
