Palmer Pease
- Sep 26, 2017
- 5
- Joined
- Sep 26, 2017
- Messages
- 5
Greetings all, first post. I did a search to no avail.
I would like to build a circuit that will close (or open) contacts when input voltage falls below a specified value. It will need to be quite precise, within a tenth of a volt DC or less. In the 2-2.5 volt range.
Here's the project. I would like to convert my '04 GMC to electric cooling fans for the radiator/AC condenser/transmission cooler. The engine and transmission temp sensors are provided a 5v reference. When the sensors are cold the resistance is low so the return voltage is relatively high. As the fluid increases in temperature the resistance increases and the voltage drops. When the voltage drops to a specific value, I need to start triggering fans on. Most E Fan setups are two, two speed fans. I plan on four or five temperature/voltage trigger points to manage noise and electrical usage, plus provide a bit of redundancy.
Wiring the relays to control the fans is the easy part for me. Reading wiring diagrams and schematics is easy. Soldering circuit boards, resistors, diodes, relays, I'm good with all of that. Capacitors I understand but don't know the math to size them. I should have paid more attention to transistors. But I'm good with logic these days as opposed to my teens when I did the Heathkit DC electronics course
Any suggestions?
Any suggestions?
