I am looking for some possible solutions to detect how far a transmitter is away from a reciver. my current thoughts are to have a counter that increments at 300 mhz (1 meter wave length) which is sync'd with both transmitter and receiver. i than transmit this number. The receiver than takes its current number and compares it with the received number to calculate the distance.
The advantage of this approach is that the transmitter can be in a ultra low power mode for much longer (thus saving on battery life).
My question is can you see a problem with this solution? If not can you recommend an IC to implement the 300 mhz counter?
