E
en2
Hi guys.
I need a suggestion regarding one project.
Well, the project should be one micro controller battery powered device
with wifi connection. Of course, the main problem is wifi and power
consumption.
Base processor will be ARM cortex M0 and the device should be powered
with 3,6V non rechargeable battery ( it's is not a must ).
WIFI range should be around 50 meter and it would be nice if i can hook
up external antenna.
Data will de send in half minute package and device should work 24/7.
Minimal work time of the device : 2 years.
I have found few ready made solutions like
- spark core ( over project budget )
- cc3000 ( TX power consumption 275mA )
- ultra low wifi ( small range )
Size of the device should be in 15x10 cm range so i can use some kind of
battery array but then again, this will be over project budget.
The main thing is to pass the data to Internet so some other solution
can be used.
consumption.
can be used.
