Low Current Measurement (without ammeter)
Hello Everyone,
I have an application that uses 3 displacement sensors with analog
current output from 0 to 20mA. I have a real time DAQ system that only
measures voltage from 0 to 10V. I have read the previous response to
Pradheep's question and it seems like the current values are too high
to get the kind of precision that I need. I was wondering if I could
use the resistor in series method and if there was some trick that
could help me develop this setup? Any help at all would be appreciated,
because I've never had to measure currents like this before so I'm a
little beside myself trying to figure this one out...Also if the
resistor "shunt" is placed in series what kind of accuracy can be
achieved?
John O'Flaherty
Hello Everyone,
achieved?
If you put the current into an opamp inverting input, with a 500 ohm
feedback resistor, and the non-inverting input grounded, it will
convert 0-20mA to 0 to -10V, and the output will be stiff even if it's
loaded a little. You'd have to invert the output to +10 V. If the opamp
needs to be protected from voltages, you can use a series resistor with
diodes to plus and minus supply on the opamp input to limit voltage
excursion, but you'd have to make sure the current source has enough
compliance to handle the extra resistance. The source will only need
enough voltage compliance to handle the drop across that protective
resistance.You could also just use a 500 ohm resistor, if the DAQ
system has high input impedance. Using just a 500 ohm resistor, the
current source would have to have the compliance to produce the 10V.
thank you so much John, I will try that and post my success message
soon....
Eric Williams
(left the name off last time...thanks again)
C
Chris
soon....
Eric Williams
Look before you leap, John -- there are a few potential gotchas here.
First, not all op amps are capable of sourcing/sinking 20mA (and that
has to be a min., not typ. on the data sheet).
Second, you really have to look carefully at your system before you
just plug it in. Many sensors that output a 4-20mA (or 0-20mA) current
operate on another supply voltage, and have a simplified internal
circuit like thios (view in fixed font or M$ Notepad):
| +24V
| .------------o-----.
| | '-----|------o
| | |4-20mA
| | .-----|------o
| |.-----------o |
| '------------o-----'
| COM
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
If your sensor common is connected to DAC GND, you may have an issue
connecting the external power supply (which may exceed the DAC power
supply or the input common mode voltage) to the DAC input. And if you
connect the negative sides of more than one sensor together, it won't
work.
Another difficulty is power-up sequencing. If your sensor supply comes
up before the DAC's, you may get latchup when the DAC turns on. Not
pretty.
For current output sensors, you typically place a 250 ohm (0-5V) or 500
ohm (0-10V) load resistor at the receiving end of your signal, and then
use a diff amp to get the input voltage to the DAC. That's how it's
done.
Good luck
Chris
John O'Flaherty
That's a good point.You could put a transistor buffer on the opamp
output, or, in a one-direction application like this, you could hang a
resistor to the minus supply, pulling 10mA out. Then the opamp could
switch between sinking and sourcing 10 mA.
| +24V
| | '-----|------o
| | |4-20mA
| | .-----|------o
| |.-----------o |
| COM
work.
pretty.
Do you think using a series resistor with diodes to prevent excursion
more than V+ plus .7 or V- or ground minus 0.7 would prevent that
problem? With a hookup like that, wouldn't an early start of the sensor
supply at worst just try to power up your circuit?
done.
That seems like the best solution if you have 24V available from the
sensors.
C
Chris
sensors.
Hi, John. Depending on Eric's application, everything you suggested
*could* work -- it all depends on the specifics of his application.
Many sensors with current output are self-powered, and you just take
the current output wire referenced to it's COM wire for the 4-20mA
output. Some require the mA output be referenced to the V+ side (view
| VCC VCC
| .-------. + .--------. o-----.
| | +o-------' | +o----------' .-.
| | | | | 250| |
| | OUTo-------------. | OUTo ------------. '-'
| | COMo-------. 250| | | COMo----------. '--'
| OUT SOURCING o-----' OUT SINKING |
| GND GND
Fig. 1
Some have built-in isolated floating power supplies, and just have two
output wires -- you can tie either side to the PC common without worry.
And many aren't self-powered at all -- you apply a minimum voltage
between the two wires, and the sensor powers from that, with total
current draw guaranteed to be 4-20mA, like this:
| VCC
| | +o-------'
| | OUTo--------o Vo
| | | 250| |
| GND
Fig. 2
This won't work for a 0-20mA output (they do exist), so it's more
likely it's one of the other types of outputs unless the OP
mis-described his app.
The difficulty comes when interfacing to a PC or other DAQ system where
you have fixed voltages referenced to PC ground. It's trivially easy
to smoke a board input, and I've gotten a lot more cautious over the
years about this particular problem, in part because you occasionally
have to supply a solution before you know all the details (much like
Eric's post).
For the two wire solution shown in Fig. 2 above, if the +15V of the DAC
board is sufficient, he'd need no input protection at all. Many
sensors require more than 15V, though. With a higher power supply
voltage (say, +24V), Eric should just be able to put a 12V zener across
the 250 ohm resistor for protection.
But using a combination of voltage dividers at the input, followed by a
diff amp with enough gain to compensate for the voltage divider, is
good as a universal input which can accept common mode voltages quite a
bit above the power supply rails.
The concept I mentioned above is expressed as a one-IC solution from
Analog Devices. The AD629 is a high common mode voltage diff amp which
has laser trimming to achieve minimum offset and gain error. For a few
bucks per channel, he can have a universal front end that can handle
common mode voltages of up to +/-270V with the +/-15V supply commonly
available on DAQ boards. The low end version of the AD629 specs 1mV
max offset and 0.05% max gain error, which is a small price to pay:
http://www.analog.com/uploadedfiles/data_sheets/225410897ad629_a.pdf
Eric can also implement the high common mode voltage diff amp with
discrete components and standard op amps, just as shown in the
suggested wiring diagram on the data sheet. Resistor matching is a bit
of a pain though, especially with multiple channels. If the OP wants
to go that route (been there, done that, got the tee-shirt), having a
factory cal cycle and/or autocal cycles can help with offset and gain
non-linearities. And after all, the OP didn't specify accuracy or
precision here -- he was just asking. And I don't remember needing
more than 12 or 13 bit resolution on any position or displacement
sensor output signal -- actually, 10 or even 9 bits (0.1% or 0.2%)
would almost always have been sufficient.
If the OP wants to look at the wide variety of current sense solutions,
he might want to look at Linear App Note 105, the Current Sense Circuit
Collection.
http://www.linear.com
Punch in AN105 on search, and right-click "Save Target As..." (long
..pdf file alert). They don't cheat too much toward their product, and
one of those solutions should be right for the OP.
Cheers
Chris
