Looking for Templates for an Analog Circuit to Control LEDs from a Photo Diode
Gebhard Sengmüller
Nov 24, 2017
4
Nov 24, 2017
4
Hello everyone on the forum,
I am trying to build an electronic circuit that can drive a bright array (size appr. 40 by 60 mm) of white LEDs from a photo diode. By that I mean that the LED array should be able to change its brightness according to the brightness induced to the photo diode. This should work with a maximum frequency of 2 MHz. The circuit should also include a potentiometer to gamma correct the signal.
I need this for a mechanical television system I am building, as described here: http://gebseng.com/11_big_paul/big_paul_brochure.pdf
Since this system (the spinning Nipkow Disk) blocks out 99.99 percent (sic!) of the available light, the photodiode needs to be very light sensitive, and the LED array needs to be very bright.
As you can probably tell from this writeup, I am not an electronic engineer myself, but I have decent soldering skills and a basic understanding of analog electronic parts.
If you could suggest a tutorial, or even better existing examples for similar circuits that I could modify for my purpose, this would be very helpful. I am not sure what the right terms for this kind of circuit are, but I guess it can't be too exotic.
best,
geb
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
What are the voltage and current requirements for the LEDs?
ak
Gebhard Sengmüller
Nov 24, 2017
4
Nov 24, 2017
4
Thanks for your reply!
I don't really have voltage and current requirements so far. I need to build an array of LEDs that covers 40 by 60 mm, and they have to be as bright as possible, since only 0.01 percent of the light will pass through (due to the very small holes in a very fast rotating disk)
geb
Gebhard Sengmüller
Nov 24, 2017
4
Nov 24, 2017
4
About the LED type: I am not sure if I can pick LEDs designed for lighting purposes. Are they dimmable like smaller LEDs, and can they be modulated at up to 2 MHz?
If yes, how about this one:
https://uk.rs-online.com/web/p/visible-leds/8792889/
I would arrange 54 of those in a 6 x 9 grid.
Specifications:
LED Colours White
Mounting Type Surface Mount
Number of LEDs 1
Forward Voltage 38 V
Luminous Intensity 461.5 → 547.5 cd
Number of Pins 2
Viewing Angle 120 °
Luminous Flux 1400 → 1800 lm
Lens Shape Square
Dimensions 7 x 7 x 0.7mm
Series DURIS S10
Colour Temperature 5700K
Lens Colour Yellow
Forward Current 20 → 400mA
Lens Finish Diffused
7,682
7,682
800 Watts in a 4x6 cm square? No problem, All you need is water cooling and a car radiator (with fan.)
