S
Sergey Kubushin
Hi, everybody!
I'm looking for a schematic for a logarythmic amplifier. It should work in
audio range (20 Hz - 20 KHz) and has 50-80 dB range. It doesn't have to be
very precise, it's intended use is audio amplifier's output indication with
a linear neon tube, but it must be reasonably stable. The simplistic opamp
with two germanium diodes won't do. Monolythic IC is preferrable if its
cheap enough (the cheapest I can find from AD are $10 apiece that is kinda
high) and is not packed into a case unvisible without a microscope (SO-xx
are fine and preferrable). Relatively simple opamp schematic will also do.
All the information is highly appreciated.
P.S. I don't have "The art of electronics" on my shelf here in the US and
I'm not going to buy it for a one schematic. I do have my Russian edition
that I bought when living out there but unfortunately its still collecting
dust out there, I haven't brought all my treasures to the US so far...
