P
Phil Allison
** The LM358 is a poor choice for most audio circuits - particularly if you
want low distortion.
Why?
The LM358 and its quad version the LM324 are intended for single supply rail
operation and to use very little current. To save current, the IC has an
unusual output stage compared to most other op-amps. In audio circuits,
there is a BIG problem is with this oddball output circuit - see schem on
page 21 of this pdf:
http://www.ti.com/lit/ds/symlink/lm158-n.pdf
Qs 5, 6 and 13 form a complimentary, emitter follower, current booster
supplying the output current - BUT the bases of Q5 and Q13 are linked so
there is no forward bias on the stage.
Soooo - every time current flow into a load has to change between Q6 and
Q13 - the collector of Q12 has to *jump* a nearly 2 volt gap created by the
three B-E junctions involved. During the time this takes to happen, NO
output current flows. This results in "crossover distortion" at the output
which becomes worse and worse as the frequency rises.
On page 8 of the pdf, the makers allude to this fact:
" For AC applications, where the load is capacitively coupled to the output
of the amplifier, a resistor should be used, from the output of the
amplifier to ground to increase the class A bias current and prevent
crossover distortion. Where the load is directly coupled, as in DC
applications, there is no crossover distortion."
This is hardly an adequate explanation of the issue.
In the AC coupled case, one has to fit a resistor to ground of such a value
that Q13 is never required to conduct current - which could mean a very low
value resistor has to be used and is simply not practical.
In the DC case, the wording is quite misleading. Only if the load is
connected directly to ground and the negative supply is also the ground is
the comment true.
In the general case where the load is connected to a ground point that sits
between the supply rails - then Q13 has to supply current and serious
crossover distortion is the result.
BTW:
A low current, dual op-amp that IS suitable for audio is the TL062 and its
quad version the TL064. Supply current is less than 200uA per amplifier and
operation right down to +/- 2 volts is OK.
And definitely NO crossover distortion !!
http://www.ti.com/lit/ds/symlink/tl062.pdf
.... Phil
Why?
the comment true.
BTW:
.... Phil
