H
HC
Hey, all, I tried to build a circuit that I found online and had a
problem with it. I e-mailed the creator but didn't get a reply so
here I am.
What I have is a 120VAC device that switches on and off through
existing circuitry; it is a fully functioning device and circuit.
Periodically the existing circuitry will power up the device for a
period of time. I want a circuit that will detect when the current
device cycles from off to on to off and, upon returning to the off
state, will enable a second device for a configurable period of time.
That is, I have a circuit (I did not create or build) that controls a
120VAC load. I want to introduce another 120VAC load that will run
for a set amount of time each time the original load turns on and then
off.
My goal is to use a 555 timer in mono-stable configuration controlling
a 5 VDC relay to switch the 120VAC line voltage to my second load. I
found this circuit:
http://ourworld.compuserve.com/homepages/Bill_Bowden/page10.htm
Look at the third circuit under AC Line powered LEDs.
I bought all the components specified except the 270 ohm 2 watt
resistor. I had to buy two 560 ohm 1 watt resistors and run them in
parallel (measured 273 ohms). The thing works..but the resistors get
hot as sin in about 30 seconds and the whole time the voltage is
creaping up. When I say hot I mean they are painful to touch and give
off an odor. I added two more resitors for a total of four, two in
series, two series in parallel and still they get hot (painful). With
the four in parallel/series I measured a little over the 560 ohms the
capacitors were designed to be. Still, that's over twice the
resistance the orginal circuit calls for and I thought that would
reduce the current and therefore the heat. Apparently I am wrong.
I did some searching in here before making this post and the best I
found as an alternative is on Microchip's site:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en011121
It's TB008.
I can do that (see Figure 4 in that PDF) but I only have 1.5 uF
capacitors in that voltage range (specially purchased for this
project) and, mostly, I hate to abandon an idea that fails without
understanding the failure. Plus, the Microchip shematic doesn't
indicate the wattage of the resistors (that I noticed) whereas the
first circuit I listed does...so I'm wondering if I can get away with
1/4 watt resistors or not. I bet I make popcorn. And, as I get
nervous as hell handling 120VAC in these kinds of situations
(electronics where wires are bare and alligator clips are in use), I
thought I'd see what experience might be out there to learn from.
I could get transformers but that will make my project much more bulky
and I'd like some finesse here.
Thank you for your time and help.
--HC
here I am.
off.
found this circuit:
It's TB008.
--HC
