A
Andy
I have a cheaply made light to be worn on the head. It consists of 5
white LEDs each of which I guess would each draw about 40mA. (Is that
right?) So the total current requirement might be around 200 mA.
The power is 2 lithium button cells in series. These are type 2032 each
with a nominal capacity of approx 2000 mAh (if a good brand) and probably
less with the generic cells the lamp was supplied with.
Simplistically I would say that a 200 mA load can be satisfied for 10
hours from a supply of 2000 mAh.
But that sounds like an overestimate and I've no idea what end-
voltage/end-current is needed to power white LEDs. Nor if the discharge
of a lithum cell is approx linear.
So I am asking you guys if anyone is able to provide a better *estimate*
of long such a 5 LED device would last for?
(Nope - I don't want to waste a pair of lithium cells if this can be
determined by theory!)
Andy
Andy
