Rui Almeida
- Nov 3, 2016
- 23
- Joined
- Nov 3, 2016
- Messages
- 23
Ok Maxwell, any help from you is much appreciated.
I think you have to be patient with me, because I don't have an electronics course. The FET you are talking about, is it the power switching diode D34(D39), or is it something else? I have doubts on how I should measure the base to collector current on these small SMDs, but I think it's this current I measured flowing through the R11(R12) resistor. The way I did this was, I measured with my multimeter the voltage drop across R11(11.7V) and used Ohm's law to calculate the current going through to Q3(Q4) . The Q3 components I bought were these:, so I think they can handle that current, and the D34 components were these.
I don't know what all these components do in the circuit, there are so many, and the technical figure above doesn't help much.
Alternatively directly measuring the collector to base current would imply desoldering them, connecting them through wires to the PCB so that I can insert my multimeter in the circuit, right?
Since the stove has two of these PCBs and the left one does work(most of the time) I can take them both out and compare in-circuit multimeter measurements of resistances and diode readings of other components in the circuit of these burned parts. Thinking about desoldering a hundred or so, tiny SMD components to test them is indeed discouraging, but if must be...
