board=leonardo
boardsmanager.additional.urls=
build.verbose=true
build.warn_data_percentage=75
compiler.warning_level=none
console=true
console.auto_clear=true
console.error.file=stderr.txt
console.length=500
console.lines=4
console.output.file=stdout.txt
custom_cpu=mega_atmega2560
editor.antialias=true
editor.caret.blink=true
editor.code_folding=false
editor.divider.size=2
editor.external=false
editor.font=Monospaced,plain,12
editor.indent=true
editor.invalid=false
editor.keys.alternative_cut_copy_paste=true
editor.keys.home_and_end_beginning_end_of_doc=false
editor.keys.shift_backspace_is_delete=true
editor.languages.current=
editor.linenumbers=false
editor.save_on_verify=false
editor.tabs.expand=true
editor.tabs.size=2
editor.update_extension=true
editor.window.height.default=600
editor.window.height.min=290
editor.window.width.default=500
editor.window.width.min=400
export.applet.separate_jar_files=false
export.application.fullscreen=false
export.application.platform=true
export.application.stop=true
export.delete_target_folder=true
gui.scale=auto
last.folder=G:\Documents\Arduino\Projects\Capacitor Tester\Capacitor Tester - LCD Output I2C\Capacitor_Tester_-_LCD_Output_I2C\Capacitor_Tester_-_LCD_Output_I2C.ino
last.ide.1.6.6.daterun=1458648802
last.ide.1.6.6.hardwarepath=C:\Program Files (x86)\Arduino\hardware
last.ide.1.6.8.daterun=1464999733
last.ide.1.6.8.hardwarepath=C:\Program Files (x86)\Arduino\hardware
last.ide.1.6.9.daterun=1465508687
last.ide.1.6.9.hardwarepath=C:\Program Files (x86)\Arduino\hardware
last.screen.height=1080
last.screen.width=1920
last.serial.location=0,0,655,371
last.sketch.count=1
last.sketch.default.location=-4,-4,1928,1054,481,6
last.sketch.default.path=C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
last.sketch0.location=-4,-4,1928,1054,481,6
last.sketch0.path=C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
last.sketch1.location=-4,-4,1928,1054,836,6
last.sketch1.path=G:\Documents\Arduino\Projects\Capacitor Tester\Capacitor Tester - LCD Output I2C\Capacitor_Tester_-_LCD_Output_I2C\Capacitor_Tester_-_LCD_Output_I2C.ino
last.sketch2.location=-4,-4,1928,1054,836,6
last.sketch2.path=G:\Documents\Arduino\Projects\Capacitor Tester\Capacitor Tester - LCD Output I2C\Capacitor_Tester_-_LCD_Output_I2C\Capacitor_Tester_-_LCD_Output_I2C.ino
platform.auto_file_type_associations=true
preproc.color_datatype=true
preproc.enhanced_casting=true
preproc.imports.list=java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
preproc.output_parse_tree=false
preproc.save_build_files=false
preproc.substitute_floats=true
preproc.substitute_unicode=true
preproc.web_colors=true
programmer=arduino:avrispmkii
proxy.manual.hostname=
proxy.manual.password=
proxy.manual.port=
proxy.manual.type=HTTP
proxy.manual.username=
proxy.pac.url=
proxy.type=auto
recent.sketches=C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino,C:\Program Files (x86)\Arduino\examples\01.Basics\Fade\Fade.ino,G:\Documents\Arduino\Projects\Capacitor Tester\Capacitor Tester - LCD Output I2C\Capacitor_Tester_-_LCD_Output_I2C\Capacitor_Tester_-_LCD_Output_I2C.ino,F:\Documents\Arduino\Projects\Accelerometer LCD2004 I2C\Accelerometer_LCD2004_I2C\Accelerometer_LCD2004_I2C.ino,D:\My Documents\Arduino\libraries\Time\examples\TimeRTCSet\TimeRTCSet.ino,F:\Documents\Arduino\Projects\Temperature\Temperature - DS18B20\DS18B20 - LCD Output I2C\DS18B20_-_I2C\DS18B20_-_I2C.ino,C:\Program Files (x86)\Arduino\examples\06.Sensors\ADXL3xx\ADXL3xx.ino
run.display=1
run.options=
run.options.memory=false
run.options.memory.initial=64
run.options.memory.maximum=256
run.present.bgcolor=#666666
run.present.exclusive=false
run.present.stop.color=#cccccc
serial.databits=8
serial.debug_rate=9600
serial.parity=N
serial.port=COM10
serial.port.file=COM10
serial.port.iserial=null
serial.stopbits=1
sketchbook.path=D:\My Documents\Arduino
software=ARDUINO
target_package=arduino
target_platform=avr
update.check=true
update.id=6922138667809720905
upload.using=bootloader
upload.verbose=true
upload.verify=true
