BuckeyeHam
- Dec 22, 2016
- 3
- Joined
- Dec 22, 2016
- Messages
- 3
I wonder if I could get help with a problem we're having with LED light strips that I installed to replace four (4) dual fluorescent tube light fixtures in our Motor Coach/Recreational Vehicle (RV). The issue is that the water pump, and other sources, are spiking the DC voltage available at the fixtures (see attached O-Scope screenshots*) causing the LEDs to flicker. I’m curious if this problem can be mitigated at the lights by conditioning & filtering the Vdc to the LED strips, using an active DC/DC step-up (boost) switching regulator? The active device performance needs be fast and robust enough to mitigate the spikes shown in the attachments. However, any selected device/design must operate with fundamental & harmonic frequencies outside the Amateur Radio spectrum allocations on HF, VHF & UHF.
I realize that I’m attacking the effect and not the cause (the water pump, nom. 8-10A draw). However the pump is not the only potential source of voltage variations in the RV e.g. exhaust fans, 12V chest refrigerator/freezer, and perhaps a damaged Inverter/Charger (which is scheduled to be replaced).
The input DC at the LED strips is not good (10.75v) due to RV wiring/switches voltage drops. It is supposedly within the LED’s 9-12 Vdc input range, but the LEDs/strips are obviously sensitive to any variations in voltage. The LED strip pairs (2) have a combined current draw of 1.25A per fixture.
I’m looking for ideas and suggestions on device & component selection to achieve the desired results. The end game is to come up with a solution to boost the voltage up to 12Vdc and “filter” the spikes that I can replicate on each of the four (4) LED Fixtures as a DIY home project. Any help would be appreciated as this whole field of semiconductor power management is new to me.
* Variations in waveforms are attributed to variations in water flow demand. (Using a JYE DSO138 DIY Scope Kit I assembled)
