Is there anyway possible to indentify or find specifications of the lighter colored leds on this board? At first it was not working but as you can tell I replaced a couple of them with leds from the Shack that were only decribed by 3mm (size only).
Thank you.
Forgot to add. After replacing a couple of the LEDs the panel lights up now but not quiet right and thinking its because the LEDs I put in are not the correct ones.
Thank you.
