partyanimallighting
- Oct 22, 2012
- 330
- Joined
- Oct 22, 2012
- Messages
- 330
Hi guys, I have an Acclaim Lighting LED driver unit that is not powering up at all. The unit is fairly straightforward, 120VAC to 24VAC power supply (26VAC read with tester) feeding a driver PCB which in turn outputs to a total of 8 LED units. So far I've bypassed a small ceramic capacitor on the live / neutral 120VAC line in and the voltage transformer is fine, outputting 24VAC. I then reconnected the power supply outputs to the driver PCB and I'm getting 24VAC at the bridge rectifier and 36VDC out but I'm stumped from there as there's not much more I can check based on my limited electronics knowledge (basically everything I've learned, I've learned right here on this forum). There is also a small transistor or triac or regulator with a heatsink that's warm / hot to the touch but there is nothing in the display and no output. I have clearer images if necessary so I'll wait for your feedback before I proceed.
