LED Circuit Help.
Discussion in 'LEDs and Optoelectronics' started by Kamga S, Jan 4, 2017.
  1. Kamga S
    Kamga S
    Jan 4, 2017
    13
    Alright so I am making a Thank You sign using of 40 - 50 Red LEDs. Im currently having trouble figuring out the wattage and resistance needed for the circuit. At first i thought to just use a 220 ohm resistor but because there is a voltage drop between each leds im not sure it if will work . All it will be is a 9 volt battery connected to a resistor connected to 40-50 leds in parallel. the LEDs have a forward voltage of 1.8-2 volts and each LEDs requires about 20ma of current. How exactly do i figure out the wattage and resistance needed for this? Help much appreciated.
    #1
    1. Advertisements
  2. Kamga S
    Bluejets
    Oct 5, 2014
    2,226
    443
    Firstly, what is the 9v battery type?
    Bluejets, Jan 4, 2017
    #2
    Kamga S likes this.
    1. Advertisements
  3. Kamga S
    Kamga S
    Jan 4, 2017
    13
    9 volt Alkaline 500 mah and I have decided to go with a 10 watt resistor but still dont know what resistance value to use.
    #3
  4. Kamga S
    23,510
    2,176
    A small 9V battery probably won't last very long.
    Go to the resource section and read the resource on driving LEDs. It has pointers to several LED calculators which will help you in your calculations. You will be best off using one resistor per 3 LEDs.
    (*steve*), Jan 4, 2017
    #4
    Kamga S likes this.
  5. Kamga S
    Hicham
    Jan 5, 2017
    7
    Canada
    with such low amp battery, I would avoid using any resistor instead, connect bank of LEDs to form a total voltage circuit of 9v. to do that, you would connect 5 LEDs in series (or 4 depending on the LED voltage tolerance range) and the rest in parallel. This last the battery a lot longer.
    Hicham, Jan 5, 2017
    #5
  6. Kamga S
    Herschel Peeler
    Feb 21, 2016
    400
    65
    Las Vegas
    Something like this?
    Herschel Peeler, Jan 5, 2017
    #6
  7. Kamga S
    Kamga S
    Jan 4, 2017
    13
    Is it possible to use something like this?
    https://smile.amazon.com/gp/product/B00SY37S00/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Setting the converter to 2 volts and connecting the LEDs in parallel to the converter?
    Kamga S, Jan 5, 2017
    #7
  8. Kamga S
    Audioguru
    Sep 24, 2016
    1,798
    414
    An LED is driven from current not voltage. Most 5mm diameter LEDs are used at 20mA. Leds have a range of voltage because they cannot be made to be the same so if you connect a 1.8V LED to a 2V power supply then it will soon burn out because the current will be very high without a resistor to limit the current.
    Audioguru, Jan 6, 2017
    #8
  9. Kamga S
    Kamga S
    Jan 4, 2017
    13
    What ive decided to do is use an AC power adapter to run the circuit instead of a battery through a buck converter lowering the voltage to 2 volts (what these LEDs are rated for) and the the adapter has a max output of 2 Amps with the circuit im creating will draw about 1.2 amps. Could this work?
    Kamga S, Jan 6, 2017
    #9
  10. Kamga S
    donkey
    Feb 26, 2011
    1,283
    55
    brisbane australia
    I see what you mean kamga just remember 3 important parts in your design.
    output voltage HAS to be DC so if not already then throw in a rectifier bridge.
    LEDs are hungry little things.. they will consume as much current as you give them...... then turn black, small flame etc. ensure you include your resistors to limit current.
    Lastly limit the amount of LED's in a string to about 3 LEDs and a resistor. otherwise the voltage drop will make the LED's no work
    donkey, Jan 6, 2017
    #10
  11. Kamga S
    Audioguru
    Sep 24, 2016
    1,798
    414
    LEDs are not rated for 2V. They could be anywhere in the range from 1.7V to 2.2V. If all your LEDs have the minimum forward voltage of 1.7V and you apply 2.0V then POOF the LEDs are gone. If they are all 2.2V and you apply 2.0V then they will not light or they will be very dim.
    You must limit the current and have about 1/3rd of the supply voltage across the series current limiting resistor to allow for the variation in forward voltage.
    #11
  12. Kamga S
    Kamga S
    Jan 4, 2017
    13
    Alright I have finally figured out how to set up my circuit. Ill be powering it with my 12 volt AC Adapter but i have one problem. My multi meter reads 11.888 Volts when i connect directly to the adapter(No load). Is this bad? Im just concerned because im unsure if my multi meter is wrong or my AC adapter is bad.
    Kamga S, Jan 7, 2017
    #12
  13. Kamga S
    Audioguru
    Sep 24, 2016
    1,798
    414
    I hope your adapter has a DC output but you call it an AC adapter instead of calling it an AC to DC adapter.
    If its output is not regulated then without a load its output will be higher than it is rated. If it is regulated then its output will be about within 5% from 12V (11.4VDC to 12.6VDC). So either yours is regulated or your meter is wrong.
    Audioguru, Jan 7, 2017
    #13
  14. Kamga S
    23,510
    2,176
    (*steve*), Jan 7, 2017
    #14
    1. Advertisements
