Leaked Battery Motherboard Repair
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
Hello every one so my friends dad gave me an old computer its from 1990 or 1993 any way I spotted a leaking battery so I disordered it nd there is some damage so I had to remove the din connecter and where the mother board connects an old school 12pin I did this so I could see how far the damage has gone
I'm looking for advise for the lines and tracers as I'm still getting continuity but I can see the corrosion I've cleaned the area with rubbing alcohol and I've scratched off a little of the rust/oxidation
What is a good and simple way to fix this
I am very new to this and my skill level is low
tools and parts available to me
20 watt soldering iron
solder
kynar wire
solder wick/braid
rubbing alcohol
tooth brush
a chap digital multi meter
The back you can see the very bad job I did here :(
The front
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Ideally you would use a continuity meter and trace the path of the copper track to points at either end where the corrosion is not apparent and then check that the path between those two points is continuous.
On your picture I see that pin 2 of the DIN socket has a track that goes via L3 then off to the right somewhere (off picture). So measure between pin 2 and where ever that track ends up to ensure continuity. If you can't measure it then you have to solder a wire link between the two points instead.
Note that L3 (and L2) are simple ferrite beads over straight wire so have no (or very little) resistance and can thus be considered as 'short circuit' for the purpose of continuity testing.
note that those motherboards are MULTI-LAYERED and tracks can disappear through those holes to a hidden layer and reappear elsewhere. Also, desoldering from multi-layer boards needs to be done with extreme care as it is easy to strip the thru-hole plating that interconnects the multiple board layers - in which case the board will be ruined beyond repair.
Your board doesn't look too bad - if the tracks from the 'top' of L2 and L3 are ok then simply cleaning up and resoldering should fix it - assuming there's nothing else wrong around the board....
Use IPA (Isopropyl Alcohol) to clean the flux residue. Try to avoid 'scraping' the corrosion.
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
Thank you for Helping me
So Because its Multi-layered removing the components I might of damaged it even if it was working ?
Ok I had scraped away some of the corrosion I will stop doing that
cleaning up with IPA will that also neutralize the corrosion
ok so far there are only a few points I cannot get continuity
Din 2 to c86 is fine but Dine 2 to L3 there isn't any
Din 1 to L2 is fine but then Din 1 to c87 same as before isn't any
Then the Tracks where the main corrosion is there all fine
once I have cleaned the tracks do I coat them in any thing for protection like Clear nail varnish
and how hard do I clean the corrosion and green/blue residue do I say use a cotton bud or IPA on a hard tooth brush ?
I will include a better picture
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Simply removing parts from a multi-layered board doesn't necessarily mean its death knell! It's quite possible to remove parts without causing damage but once damage HAS occurred it's nearly impossible to fix. You can tell if you've caused damage as the thru-hole plating tends to remain on the removed component pin/lead and can be seen quite clearly. Time for a few sobs.....
I can see corrosion on the solder joints at L2 and L3 so make sure your test probe breaks through that corrosion and makes a good connection - same might be said of C86/87.
You need to stop the corrosion continuing - a solution of baking soda dissolved in water and applied using a cotton bud is effective. Clean up afterwards using the IPA and clear nail varnish will work well to protect it afterwards but don't expect to easily remove it if you have to at a later date!
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
Eeek ok so far this hasent happened "crosses fingers for first circuit board repair"
I Will do I clean up and continuity test before bed
I wont put on any nail vanish tonight :)
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
As Its a 20+ year old computer the power supply is a AT power supply and it connects with two 6 pin connectors
I had to remove the 12pin bracket from the board and I accidently damaged it
Do you know what that part is called
I found a replacement female din easily but not the Bracket
Here is a pic I found and I have highlighted the part
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
Wow thank you so if I buy two I can just use them instead of a 12 pin bridge ?
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Yes - although you 'might' have to trim a little plastic off the side of one..... might. They will fit.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
(one of) the most critical characteristics of any connector is its 'pin pitch' - the distance between each pin.
There are none amongst the eBay list that either match for polarity (many are female whilst the one you need is male) and the closest one to the Maplin version has the wrong pin spacing (2.54mm as opposed to the required 3.96mm)
The Maplin item should be ex-stock??? You are also UK-based so if you can't find a Maplin place locally they'll do mail order no problem. Might as well get the 'right' part at whatever cost as the motherboard, should it still work, is both valuable and an excellent 'vintage' product worth keeping.
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
Ok I understand :)
Big learning expericance thanks for teaching me
yes right part for the job
I've know ordered every thing
I will keep you updated
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
:( already need help again
old picture with outlines
its odd the only place I have no continuity is L3
if you follow the red line from C86 that's where the continuity ends even if I put one end on c86 and flip the board to the posts of L3 still nothing
but if I put 1 end on the left of L3 and one to the right it reads so L3 it self is working just no continuity to any thing else on the board
davenn
14,262
14,262
its VERY corroded around there ... I am not surprised that the tracks have been eaten away and the tracks going down from the right sides of L3 and L2 as well
around the right pins of C85, 86 and 87 .... around the pins of R29 - 34 ..... around JP3 ...... around the pins of the IC below JP3
You must clean ALL of that up and there is probably more that I cannot see
actually there is corrosion all over that area board that needs to be cleaned off. Heavens only knows how much is around the pins of the memory module sockets
The BIG IC socket below the memory module sockets is all corroded
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
As Davenn points out, the corrosion must be stopped/removed. I'm not entirely sure but there does appear to be a break in the track just above L3 (on the left side) but only you can tell.
Have you cleaned the board as per my earlier post? Get it well coated with the baking soda solution and use a tooth brush to scrub as much corrosion off as possible - rinse the soda off with fresh water, dry, then wash with IPA and leave to dry again.
If you get board powered up and there is still corrosion present it will get worse FAST.
Use a magnifying glass to trace the tracks and ensure your probe has a sharp point to break the surface crud to get a reading. You might have to desolder/resolder the more heavily corroded parts and 'pray' that corrosion hasn't got down the plated holes and broken the interlayer bonds....
XsamX1987
Jun 24, 2017
29
Jun 24, 2017
29
board2.jpg Sorry I said that was an old picture here is the new one
ferrite beads removed now
Baking soda went very well
but I can see where the lines are just dead
continuity check
C86 to 2 OK
1 to D OK
C87 TO 1 OK
2 TO C BAD
B TO R29 OK
A TO R31 BAD
AN NO CONTACT BETWEEN A AND C AND B AND D
memory module sockets look fine checked all around IC socket has been cleaned
So what do you guys think is it 100% dead time for the bin ?
