pusur44017
- Nov 16, 2015
- 32
- Joined
- Nov 16, 2015
- Messages
- 32
Please refer to this.
with the coding found here.
First, the cost is an issue. Am I in the clear by utilizing 2 of these?
I would like to add and tweak the lighting modes. I have programmed before, on a very beginner level, and I understand some of the code this project uses, but I need help. If you have problems understanding what I am talking about, please refer to the video in the first link.
*For the lightning mode, I would like to add speakerless activation. (in addition to the speaker one) (*)
*For the changing color (not trippy/acid as described by the website) I would like it to slow down. (*)
*I would like to add a slow changing white mode, which just fades in and out. (**)
*A dimmed version of the thunder effect (addition to other thunder effects) (*)
(*) = tweak to exsisting mode
(**) = New mode
There are already 3 modes in the code, if I can do this, I want there to be 6 in total, but some of them, I believe can be archived by simply copying existing code and changing a few parameters. I should also add that I have never programmed Arduino, but I am going on a course to learn, but shipping will take so long that I need to order now, and for me to want to make this project, I want to have at least some of the modes I describe.
Feel free to ask if you need more information on the components I plan to use or other.
(All components *should* be the same as described in the post)
I will also need help with other parts of this project and if you think this is interesting and want to help, have a look here.
Thank you in advance,
-pusur
(**) = New mode
-pusur
