Kodak 850H Slide Projector Problem
Jim S
Mar 28, 2011
Mar 28, 2011
My Kodak 850H Slide Projector is malfunctioning. When I turn it on it begins cycling as if the forward button were being pushed and doesn't stop. Any ideas on what the problem could be?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Could the button be stuck? even if the button isn't, the switch it actuates may be.
Jim S
Mar 28, 2011
Mar 28, 2011
Thanks for the reply. When I hit the forward button I can tell it registers, so assume it's not the button itself. I you might be right about the switch that the button engages. I took off the cover and the insides were more complex then I hoped. What to do...
Doug Dunlap
Feb 10, 2018
3
Feb 10, 2018
3
I am trying to repair a Kodak 850h. Does anyone know of a source for the service manual?
Doug
73's de Edd
Aug 21, 2015
3,622
Aug 21, 2015
3,622
Sir Doug Dunlap . . . . .
INFO is just below . . .what is YOUR units specific problem ?
TECHNO REFERENCING . . . . .
73's de Edd
Doug Dunlap
Feb 10, 2018
3
Feb 10, 2018
3
A metal part in the cycling mechanism for a carousel came off and I can't determine where it goes without an exploded parts diagram.
Doug
Doug Dunlap
Feb 10, 2018
3
Feb 10, 2018
3
Thanks 73's de Edd but my protection software will not let me download the library software. Is there a download pdf available?
Doug
