I got given a PC Subwoofer, Klipsch ProMedia 2.1, the sub is self powered, along with speaker outputs. What I planned on doing was figuring out how I can hook and 3.5mm male plug to it for use as a standalone subwoofer.
The system had a controller for volume and bass control, plus headphone jack and mic jack. I do not need bass or volume control or even the headphone or mic jack. just want to use it as a plane jane subwoofer.
I am going to provide the schematics to the sub, I just would like a hand on where I can send the audio signal to for the subwoofer. I have attempted a few tests with no good results. I suspect I may need to do a few things to make sure volume output is full power as I will control volume level from another source. and possible make sure bass level is either max or mid as I will have separate control for subwoofer.
any help will be much appreciated.
