K40 Laser Cutter
  1. Ian
    Ian Administrator
    Aug 23, 2006
    1,388
    355
    UK
    Ian submitted a new Showcase Item:
    K40 Laser Cutter
    Read more about this showcase item here...
    Ian, Mar 24, 2018
    #1
    1. Advertisements
  2. Ian
    KJ6EAD
    Aug 13, 2011
    1,002
    128
    Earth
    Casters instead of leveler feet is weird; probably just what they had handy that fit the holes that day. Is there no compressed air system to keep the lens clear?
    KJ6EAD, Mar 24, 2018
    #2
    1. Advertisements
  3. Ian
    Ian Administrator
    Aug 23, 2006
    1,388
    355
    UK
    Oddly they market the castors as a selling point, I'm not sure why :confused:.
    No air assist on this model either - it's a real bare-bones system. I've got a mini air compressor arriving next week, but I need to measure the barb dimensions once it arrives before I can order in any tubing. I've seen people design 3d printed clips that funnel air down the beam path, but I'm a little concerned that I'll end up with it melting at some point. My current thought is to 3d print a clamp that fits on to the top of the moving platform, with a 4mm copper pipe bent to blow near the focal point.
    Ian, Mar 24, 2018
    #3
  4. Ian
    23,807
    2,269
    Some of the things I would do or consider:
    1. Get an aquarium air pump and use it to direct air over the mirrors. This will keep them clean.
    2. Get some airflow (any at all) through the air-assist connection. It doubles as a coolant for the lens and helps stop dirt getting on the lens (a major cause of lens failure)
    3. MDF is cheap ad cuts easily. However the muck it leaves behind is terrible. If it's your laser cutter and you can decide not to use MDF, you'll be doing yourself a favour.
    4. Honeycomb is great, but hard to clean. Parallel "knife blades" are easier to clean, but stuff falls through them.
    5. Use magnetic reed switches for interlocks and have two in series.
    (*steve*), Mar 25, 2018
    #4
    Ian likes this.
  5. Ian
    KJ6EAD
    Aug 13, 2011
    1,002
    128
    Earth
    Good. It seems you've got all issues covered even if the manufacturer didn't. I used a honeycomb base and only noticed unfortunately-sized circular cutouts of ABS catching in it occasionally.
    KJ6EAD, Mar 25, 2018
    #5
    Ian likes this.
  6. Ian
    Ian Administrator
    Aug 23, 2006
    1,388
    355
    UK
    Thanks for the tips!
    I was going to direct the air-assist via a copper nozzle directed near the cutting point, which should blow most of the smoke away from travelling up in to the focal lens. Here's an example image that describes what I was going to build:
    However that wouldn't get much air flow hitting the focus lens (contained in the ring underneath the moving platform), it would just keep smoke out of the way. I had't considered your point about the air flow cooling the lens when thinking of this. Do you think it would be beneficial to get a replacement head where the air assist is channelled down the beam path and may cool the lens a little more? A bit like this one:
    Ian, Mar 25, 2018
    #6
  7. Ian
    23,807
    2,269
    I'm struggling to comprehend what they're doing with the lens on this thing. It must be totally unprotected.
    Yeah, I would get a head like the one you suggest. Also note that there is air on only one side of the lens. Bleeding some air into the other side will keep the upper side clean. You have one less adjustment too -- the air can only go where the beam does :)
    Having said that, just directing a stream of air over the lens in the current configuration would probably work too.
    Practically, the worst you'll do is destroy a lens. At 40W, the laser won't do that as fast as a higher powered device.
    #7
    Ian likes this.
  8. Ian
    Ian Administrator
    Aug 23, 2006
    1,388
    355
    UK
    Ian, Mar 25, 2018
    #8
  9. Ian
    skenn_ie
    Sep 7, 2009
    21
    I suggest that the hole in the box would be useful, and given that the laser is focused quite close to the nozzle, the power density at desk level would be quite low.
    I wonder if a kit is available that would facilitate an existing X-Y table. I have a CNC router which I would like to convert for laser or 3D printing as well as routing.
    skenn_ie, Apr 3, 2018
    #9
    Ian likes this.
  10. Ian
    Ian Administrator
    Aug 23, 2006
    1,388
    355
    UK
    I can't find the link anymore (still looking), but I saw a post on another forum about a member that burnt the table underneath the laser cutter through that hole :eek:. I imagine it would take some time, but I don't fancy risking it just in case (as there is plenty of ventilation elsewhere). Perhaps overkill, but I don't want to take a chance ;).
    If you want to use a laser diode, there are quite a few modules that should be an easy swap - perhaps something like this 5.5W version:
    https://www.aliexpress.com/item/Fre...er-cutting-TTL-module-5500mw/32794985652.html
    I think it would be limited to engraving (or cutting <3mm laserply/acrylic over many passes), but it should be a straight forward swap if the CNC controller can be configured. I've seen a few people add them to 3D Printer platforms with good results. I'd really like to see the results if you do try converting your CNC router :).
    Ian, Apr 3, 2018
    #10
    1. Advertisements
