JVC Speaker getting power but not producing sound
Discussion in 'Troubleshooting and Repair' started by SThundur, Jan 8, 2017.
  1. SThundur
    SThundur
    Jan 8, 2017
    12
    I recently received two JVC speakers from a friend and one of them works fine, but the other produces no sound. It is getting power in both the left and right channels. I really have no idea what is wrong with it. I do not know much about speakers so keep that in mind.
    #1
    1. Advertisements
  2. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    hi
    welcome :)
    so one speaker works but the other doesn't ?
    not sure what you mean by that, please clarify ?
    do the wires to the speakers just disappear into the speaker cabinet, or are there connections on the backs of the speaker cabinets ?
    davenn, Jan 8, 2017
    #2
    1. Advertisements
  3. SThundur
    SThundur
    Jan 8, 2017
    12
    One speaker does work. The connection is on the backside and is connected using the red and black wires.
    #3
  4. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    OK
    so what happens when you move the possibly faulty speaker to the working channel ?
    is it dead or does it work ?
    this determines if it is a speaker or amplifier channel that is faulty
    davenn, Jan 9, 2017
    #4
  5. SThundur
    tedstruk
    Jan 7, 2012
    447
    7
    Toledo Washington
    If it works its not the speaker .... right?
    tedstruk, Jan 9, 2017
    #5
  6. SThundur
    SThundur
    Jan 8, 2017
    12
    I put it in both channels and it still didn't work, I also switched the cables and nothing. I'm sure it's the speaker. But it's getting power.
    SThundur, Jan 9, 2017
    #6
  7. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    OK that would indicate that you have at lease 1 speaker faulty
    open it up if possible and see if there are any broken wires
    davenn, Jan 9, 2017
    #7
  8. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    correct
    davenn, Jan 9, 2017
    #8
  9. SThundur
    SThundur
    Jan 8, 2017
    12
    I already opened it up and no wires are broken or look wrong.
    #9
  10. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    it is possible for a speaker to fail without any obvious signs
    is it a single or multi - speaker cabinet .... please show a photo of the inside of the cabinet
    so I can clearly see what wires go where
    davenn, Jan 9, 2017
    #10
  11. SThundur
    Audioguru
    Sep 24, 2016
    1,940
    449
    Inside the speaker cabinet, measure the resistance of the speakers, and any crossover coils.
    I found two large Sony speakers on the curb (thrown away as garbage). They have 10" woofers with small magnets and the cheapest looking 3" "tweeters" I have ever seen. The tweeters were burnt out. My cheap clock radio has a similar looking 3" speaker. I replaced one tweeter and the speaker still sounded bad because the woofer simply makes boom, boom sounds.
    Audioguru, Jan 9, 2017
    #11
  12. SThundur
    SThundur
    Jan 8, 2017
    12
    https://imgur.com/gallery/X8Hso here are a few pictures that may help.
    #12
  13. SThundur
    duke37
    Jan 9, 2011
    4,872
    631
    Derbyshire. UK
    What do you mean by 'getting powe'. Some speakers come as a pair with power going in to one box to supply an amplifier which drives both speakers.
    If the speakers are the more powerful type with just a red and black lead going in, take an analogue meter, set it to the lowest range and measure the resistance between the red and black wires. A good speaker will measure about 5Ω and there will be a click when the meter is connected.
    Edit
    Got the pictures at last. They are three way speakers with some crossover components in a bass reflex cabinet. Measure the resistance across each driver.
    Note that when the back is replaced it must be sealed to get the right frequency response.
    duke37, Jan 9, 2017
    #13
    SThundur likes this.
  14. SThundur
    Audioguru
    Sep 24, 2016
    1,940
    449
    It is unlikely that all 3 speakers are burnt out unless it was connected to 120VAC for a fireworks show. Therefore I suspect that its main input wires are broken or quick disconnect connection has a bad crimp.
    Is this the connector on the rear?
    #14
  15. SThundur
    SThundur
    Jan 8, 2017
    12
    Yes
    #15
  16. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    still don't know what you mean by getting power ???
    put the good speaker on the other amplifier channel and see if it works
    or if you have another old speaker lying around use it instead to save risking the good working speaker
    show a photo of the back of the amplifier so we can see where the speaker lines terminate
    examine the speaker wire VERY CAREFULLY for the faulty speaker see if it has been damaged
    davenn, Jan 9, 2017
    #16
  17. SThundur
    SThundur
    Jan 8, 2017
    12
    When I set me multimeter to 200ohms, I get 0.05 on the screen for the sub. The one in the middle is getting 016 MΩ and it's set at 2000M. That one seems a little odd. The third one, also the smallest is getting 010 MΩ. That seems like a big difference. Either I did something wrong or it was the speakers
    #17
  18. SThundur
    SThundur
    Jan 8, 2017
    12
    When I put the multimeter to logic (I think that is the one for connection) and hook the multimeter up it makes the noise. https://imgur.com/gallery/RjlVO
    I this what you were wanting?
    #18
  19. SThundur
    SThundur
    Jan 8, 2017
    12
    I think I have found my problem, there is a capacitor that is not working going to the middle speaker. In the speaker, the sub is the closest to the input where I would put the wires, so shouldn't the sub work? I should have spotted that sooner, sorry if I have wasted anyone's time.
    #19
  20. SThundur
    davenn Moderator
    12,542
    1,546
    Sydney, Australia
    you should be using Ohms setting
    what makes you think it isn't working ?
    you still didn't answer my Q's...
    1) what happens when you put the good speaker on the other channel ? or preferably some test speaker
    2) did you inspect the speaker line carefully for damage ?
    3) no that wasn't the pic I wanted ..... I want to see a pic of the speaker connections on the back of the amp
    davenn, Jan 9, 2017
    #20
    1. Advertisements
