A
AC/DCdude17
X-No-Archive: Yes
The common rules for choosing a replacement AC adapter are match the
voltage and amp should be equal or greater than the original AC
adapter. This makes perfect sense in theory, although the small
transformer in AC adapters have a horrible regulation. A 12V AC adapter
often puts out 16 to 20V under no load and is designed to give 12V when
loaded to rated current. Once it's loaded to rated current, I^2R drop
brings the voltage down to 12V.
If you have a walkman that takes a 4.5V @ 250mA and use a 1A
adapter, it will probably send out 6-8V with only 250mA of load. The
walkman most likely has a linear regulator inside, so it should be ok in
a short term, but higher input voltage means higher dissipation which
may cause premature failure.
