please give a full answer
thanks
Yes. Look for composite to vga converters. You can buy them. Buying is
the the act of handing over money to a clerk and receiving a good, in
this case said converter. You can then connect the converter to your DVD
player using a thing called a cable which has "connectors" on both ends.
One connector goes into the DVD player, one in the converter. Another
cable connects the converter to the VGA screen. Interestingly, these
cables are commonly called VGA cables.
Som much for the full answer. I will not give you suggestions for the
converters themselves, since there are too many out there.
Oh, and since this is the electronics group, not the video group, yes,
you can buy those converter chips online as well.
