Is 24V AC dangerous?
Discussion in 'General Electronics Discussion' started by vicara12, Jul 11, 2018.
  1. vicara12
    vicara12
    Jul 11, 2018
    6
    Hi, first post here!
    I have just bought a power supply (a DIY kit) and I realized that the wires from the input voltage (24V ac) are exposed, so I am afraid of touching them and get hurt. Is 24V ac dangerous? I have seen in a lot of forums that it depends on the person, so I have to say that I am young and without any kind of heart desease.
    #1
  2. vicara12
    davenn Moderator
    12,937
    1,655
    Sydney, Australia
    Welcome to EP :)
    as a rule, no, it requires around 50+ volts to break down skin resistance to allow significant current to flow
    BUT if your hands are wet ( and they shouldn't be whilst playing with electronics) then you have lost a lot of that protective skin resistance
    There are also other factors, eg, if the current flows from one hand to other via the chest/heart
    compared to just going into one hand
    davenn, Jul 11, 2018
    #2
    vicara12 likes this.
  3. vicara12
    Tha fios agaibh
    Aug 11, 2014
    1,730
    569
    Generally anything under 30v is considered safe (at least for the heart). It is said that as little as 0.1 amps of current can electrocute someone but at voltages under 30v the skin resistance is high enough to prevent currents from reaching dangerous levels.
    If you have a power limited 24vac your pretty safe , but if you have 24v with high amperage potential its dangerous because it can cause a fire.
    Edit, Dave beat me to the punch.
    Tha fios agaibh, Jul 11, 2018
    #3
  4. vicara12
    vicara12
    Jul 11, 2018
    6
    Thanks for your reply! I think it would be better to be careful and make a wooden case for it :D
    #4
  5. vicara12
    Bluejets
    Oct 5, 2014
    2,924
    562
    Power supply input is 24v ac.... That seems strange .... no mains supply anywhere?
    Bluejets, Jul 11, 2018
    #5
  6. vicara12
    davenn Moderator
    12,937
    1,655
    Sydney, Australia
    the 24V AC is most likely the output of some plug pack etc
    davenn, Jul 12, 2018
    #6
  7. vicara12
    Bluejets
    Oct 5, 2014
    2,924
    562
    yes, did think about that.
    I guess one has to just assume sometimes.
    Bluejets, Jul 12, 2018
    #7
  8. vicara12
    vicara12
    Jul 11, 2018
    6
    vicara12, Jul 12, 2018
    #8
