IR led light powered by car battery.
Discussion in 'LEDs and Optoelectronics' started by johnpuppa, Apr 20, 2017.
  1. johnpuppa
    johnpuppa
    Apr 20, 2017
    Hello,
    I'm trying to build a small project using arduino and I would like to control a 12V lamp through a mosfet.
    As a power source for the lamp I was thinking of a 12V car battery.
    The lamp I'm planning to use is this:
    http://www.ebay.co.uk/itm/96-LED-In...t-Lamp-For-Security-CCTV-Camera-/162184422490
    From my analysis, since a small car battery has around 60A, and leds drag as much current as they can, I don't think I can directly attach the battery to the lamp. Am I right?
    If I want to limit the current to a 2A I would need a 6ohm resistor as 12/6 =2A. However 2A * 12V is quite a lot of dissipation... and I would need a a 24W resistor to be safe.. Am I right with this analysis??
    Am I better off considering a different type of battery?
    Thanks!
    #1
    1. Advertisements
  2. johnpuppa
    KMoffett
    Jan 21, 2009
    661
    63
    Minnesota USA
    The lamp is spec'd at 12VDC/15W. So it will only draw 1.25A. It has internal current limiting. "Generally" when LEDs are spec's as a specific voltage, like 12VDC, they have internal limiting.
    Ken
    KMoffett, Apr 20, 2017
    #2
    73's de Edd likes this.
    1. Advertisements
