george2525
- Jan 30, 2015
- 170
- Joined
- Jan 30, 2015
- Messages
- 170
Hi
Im having trouble with the real version of the simulated inverting op amp below
I need to attenuate 0.1-3.1 volts input by 1/50
As shown the output for 0.1V input should be about 2mV
the simulated version is close enough
What I actually get is close to 3mV
if I increase the input to 0.2V the output is (0.2/50)+1mv = 5mV
But I need the output to double!
I have seen this exact ratio and op amp model used in other circuits to attenuate voltages of similar value and noone ever mentions an offset of any kind. the simulated version works well enough.
Ive seen things on op amp biasing and adding extra resistors etc but i dont know what to do.
I need the feedback resistor to be 1K or 2K and the input must be inverted and attenuated by around 1/50
I have tried the TL072 and LM324 op amps. I cant use anything that cannot run off +/-6V
im sure the TL072 is appropriate anyway
Any ideas about how I can get a nice attenuated output that is proportional to the input without any weird 1mV shift???
