John Fields said:
View with a fixed-pitch font:
Vcc
[10k]
|<--+----O| >-->OUT
O
GND
Thanks so much for the response, but I'm not sure I understand.
The switch goes to ground on one wire, and the output of the circuit
on the other wire. What's happening with Vcc and the input/output of
the 4069 isn't clear to me.
Also, there are two connections for the switch on the circuit board.
One seems to be ground, and the other seems to have 5v on it and
registers a button press when it's tied to ground.
Can you provide a little more info? Thanks again.
Actually, the simplest thing to do would probably be to replace the
switches you've got with normally-open switches, but...
On your ciruit board, there are basically two ways it could be wired
for the switch:
+5V
[R]
| <--O--A1
O-------A2
GND
+5V
| <--O--B1
O-------B2
[R]
GND
In either case, if you measure the voltages at the connections (pads)
for the switch, you'll read 5V (Vcc) on one pad and 0V (ground) on the
other, as you found. However, if you measure the voltage on either
pad when they're tied together (as would be the case when a
normally-open switch was made) they will read either +5V or 0V. If
they read 0V, then the circuit will be wired as in A1A2, above. If
they read +5V, then it'll be wired as in B1B2. The difference is that
in A1A2 the pullup resistor is wired to +5V, and in B1B2 it's a
pull-down resistor and it's wired to GND.
What you'll need to do is to find out which pad the resistor is
connected to, and to do that you'll either need to inspect the board
visually and track down what the pads are connected to, or measure the
resistance from the pads to ground and Vcc. You'll almost certainly
find that one pad is wired directly to Vcc and the other pad is wired
to ground through a resistor, or that one pad is wired directly to
ground and the other pad is wired to Vcc through a resistor.
You could also measure the voltage on one of the pads and then short
the pads together. If the voltage changes, then the pad the voltmeter
is connected to is the pad the resistor is connected to. If the
voltage doesn't change, then the resistor is connected to the other
pad.
In any case, the pad connected to the resistor is the one you'll be
interested in, and you'll need to connect one of the 4069's inverters
to it like this:
NEW SWITCH MODS | | EXISTING MOUSE CKTY
+-----+---->| |>-----Vcc
[10k] | | | [R??]
|<--+---O| >-->| |>--+--
O | | |
+---------+---->| |>-----GND
The switch shown is your normally-closed switch, and it shorts the 10k
pullup resistor to ground, forcing the input of the 4069 low, which
causes its output to go high, fooling the mouse into thinking that the
switch is [normally] open. When the switch is pressed, it opens,
pulling the input of the 4069 high, forcing its output low, fooling
the mouse into thinking that the switch is closed. You'll need to add
the 10k resistor to the circuit as shown, and you may need to remove
the resistor (R??) on the PCB if it loads down the output of the 4069.
Try it; if the circuit doesn't work when it's connected to the mouse
guts, measure the voltage on the output of the 4069 with the switch
un-pressed and pressed. Un-pressed should read pretty close to +5V
and pressed should read pretty close to 0V. If it doesn't, unsolder
one end of R?? and try again. If it still doesn't, well... we'll
cross that bridge when we get to it.
Finally, you'll need to connect the unused inputs of the 4069 to
ground or Vcc. It doesn't matter which, they just shouldn't be left
floating.
