Good day,
I have designed a couple USB 2.0 to serial devices but am only a recent graduate (as of last Saturday) and have been asked to interface with a cell module using ic-usb. I have read the ic-usb addendum to USB 2.0 but will need to make sure the device will be robust enough to last at least five years.
A few key elements that I am aware to design in are:
1. 90 ohm differential pair
2. Short traces (<10cm)
Design criteria:
1. Lithium battery powered.
2. The microcontroller (EFM32 Giant Gecko) and the Cell module are supplied from the same source at the same potential.
3. Trace length of D+ and D- will be <18cm
I used Saturn PCB Design Toolkit to help with the trace impedance. My trace width is 10mil (0.254mm)and height to reference plane is 7.5mil (0.1905mm). Using Coplanar Wave the impedance approximates to 61.412 ohms therefore I added a resistor in series with the D+ and D- traces.
Does anyone have experience with ic-usb? Is a 29 ohm resistor the only passive component needed on this short of a trace. I understand that on other USB devices a decoupling capacitor is often added but I believe that is due to the inductive impedance of the long cables often on the devices. Please correct me if I'm wrong.
I noticed that Texas Instruments has a dedicated ic-usb voltage translator (TXS0202) but since both ICs are running off the same 3.3v source I thought this would be overkill.
Attached is a quick schematic of what I intend. Since I'm not using Vbus to supply the cell module I'm tying VregIn and VregOut together with a 4.7uF capacitor as in Silicon Labs' "USB Hardware Design Guide" AN0046 - app note.
Design criteria:
