M
Michael
I just spent two days in Ge Security Training, formerly Ge Interlogix, and
learned a lot. They mentioned installing resistors, and I wanted to know
how ya'll professionals did it. From the class I gathered, some install the
resistors at the panel, others sodder them at the devices, while others
disable the software that requires them. What is the best thing to do, and
what is the best way to do it?
I finished the structured wiring for the poured concrete home I'm working
on, I'll start the security tomorrow and finish it when the doors are hung.
I learned that the drywall is hung on a metal strip that runs 12 inches on
center throughout the Styrofoam. To run my lines, I took a drill with bit
and used it to carve out my trench. Then once the wire is in place, you
take left over installation from the air conditioning install, cut it into
strips and place it over your wire. Then you fill in the rest of the gap
with spray can foam. This is what the electricians and plumbers did.
As far as installing the wire for the windows, the contractor told me to
drill diagonally to the window to get my line close. This proved
frustrating, since it was a guess as to the angle to take. Called the
contractor back up, and he said just drill as close as you can, then the
drywallers will notch the drywall, will see. I went to the outside of the
window and drilled in. This meant drilling through the concrete, but it
wasn't so bad. You should definitely charge more for this type of install.
Thanks to the group for the help.
