R
rob
Hi to all.
I am trying to match a 50 ohm source to a parallel tuned cct at
13.56Mhz.The parallel
cct consists of 140nH // 984pF . The actual cap would be a fixed value
ie 820p in parallel with a variable cap.
The problem is that I don't know the resistance of the parallel tank
at resonance.The theoretical resistance (perfect inductor , cap) is
infinite. The DC resistance of the coil is less than 0.1 ohms. This
would give a dynamic impedance of 2.8K ohms if R is 0.05 ohms. ( Rd =
L/R.C)
This does not take into effect skin effect of the wire and other
parasitics.
I then thought I would try and measure the impedance of the cct at
resonance.
Would the following method give acceptable results or am I barking up
the wrong tree!!
1. Connect the tuned cct to a signal generator via a 1K resistor.
2. Set the signal gen to 1V out at 13.56Mhz
3. Tune the resonant cct to resonance using a scope (watch for peak)
4. calculate the dynamic impedance using basic voltage divide rule.
Peak voltage across
tank being Vx. Vx = (1v * Rx) / ( Rx + 1K)
Using this method I get a value of 315 ohms.
Does this sound at all correct? I have not taken into account the
capacitance added by the scope probe. I assume this should not make to
much difference to the result , because once removed the cct can be
re-tuned.
I would then match 315 ohms to 50 with a l-match.
As I said before , would this method give acceptable results.
Cheers
Rob
L/R.C)
parasitics.
resonance.
the wrong tree!!
Peak voltage across
re-tuned.
Cheers
Rob
