Alexander8046
- Sep 24, 2017
- 5
- Joined
- Sep 24, 2017
- Messages
- 5
A few days ago I saw this article on Instructables.com (http://www.instructables.com/id/Build-The-Worlds-Loudest-Alarmclock/) that shows you how to rig a car horn to a cheap alarm clock. I wanted to do this so I bought everything and got to work.
Parts:
Motorbike Horn (12V 1.5A DC)
Wall power adaptor (12V 2A DC)
IRF540N HEXFET Power MOSFET (https://m.ebay.co.uk/itm/IRF540N-HE...043399?varId=490205044826&txnId=1424930910009)
2N3906 PNP TO-92 Transistor (https://m.ebay.co.uk/itm/2N3906-PNP...650234?varId=590358508478&txnId=1477261816019)
Alarm clock with 1.5V DC trigger signal
10K Resistor
1K Resistor
I disassembled the alarm clock and found that the beeping sound was produced by a tiny 1.5V buzzer. I de-soldered it and connected a female 3.5mm jack to the buzzer’s wires so that I could connect an aux cable to the alarm clock when needed.
I then made the driver circuit using the diagram attached but it did not work. The horn would make a constant long sound as soon as I connected the 12V DC source and wasn’t affected by the voltage (or absence of it) from the alarm.
So that’s what I need. A circuit that can take a 1.5V DC signal and use it as a trigger to allow a 12V 1.5A DC current to flow through a horn.
Any ideas are welcome.
(Please bear in mind that I only have a limited understanding of how electrical components interact so a diagram would be very helpful!)
Parts:
10K Resistor
1K Resistor
