IDC dip plug pins >:(
N
name1
Anyone know why IDC dip plugs have their pins staggered opposite of what
standard dual row IDC connectors use? Argghhhhhh! I assumed it was
otherwise.
In other words on a dip plug red wire one goes to pin 2, and wire two goes
to pin 1...
N
name1
Oops I meant red wire one ends up going to far side/highest pin, and wire
two goes to pin 1. Talking about plain ol ribbon cable here.
In a world where there are left-hand screws, nothing is impossible.
However, I'd bet that your numbering scheme is in error. Some
conventions (e.g., JST dual-row) have pin 1 in the upper-right corner
(looking at the pin header face oriented vertically, pins 1 & 2 at the
top) and if you're used to that then the IDC schema where pin 1 is at
the upper left could make it appear that the red wire goes to "pin 2".
Ok, yes. I assumed IDC is canonical, just because ribbon cables always have
that first red wire that goes to upper left. Never used JST.
john
have that first red wire that goes to upper left. Never used JST.
Anyway I flipped my idc header upside down to the bottom of the board. Now
pins match up.
