I need a circuit where a single input triggers, 4 outputs in sequence?
Adrian999
Nov 11, 2018
Nov 11, 2018
I'm hoping someone can help me, a my mind has gone blank, and I can't work out how to build this, or what it's even called! I have an automated rabbit hutch, and the last thing I want to build is a hay feeder for when I'm away. This consists of 4 boxes, each with a small door. When power is provided to an electronic solenoid holding each door closed, it opens allows the rabbits to access the assortment of food inside. I have a spare input controlled by my phone, which I can pulse on. What I want is a circuit which each time it receives an input, triggers one of the 4 outputs. Each time it triggers it rotates round. E.g.
First time it receives an input = output to open 1st door
Second time it receives an input = output to open 2nd door
Third time it receives an input = output to open 3rd door
Forth time it receives an input = output to open 4th door
Fifth time it receives an input = output to open 1st door
etc etc
Any ideas?
Harald Kapp
13,738
13,738
A 4017 counter is (almost) ideal for this purpose.
  • Connect the pulse from the phone to the clock input (pin 14)
  • Use outputs 0...3 (pins 3, 2, 4 and 7) to control the solenoids (by using suitable drive transistors in between).
  • Connect output 4 (pin 10) to the reset input (pin 15). Thus the counter will count from 0...3 (4 states) and go back to 0 with the fifth pulse. You may have to add an additional reset circuit to ensure the 4017 starts with count=0 at power on.
  • Connect clock inhibit (pin 13) to GND to enable the clock input.
