Driver meaning the speaker itself? If it blew the speaker coil out you can measure for resistance on the speaker terminals, should be single-digit ohms. You can also set a multimeter to 20VAC range and measure for output to the speaker when it should be playing.
Does it seem to power up and work okay except for no audio? Typical faults might be the power supply itself but if it's powering up, probably not that (but you can still measure for DC voltage to the amp board), otherwise a common fault would be blowing the output transistor(s) which might be discreet or might be integrated into a power amp IC chip.
For those you'd have multimeter set to 20VAC and measure for signal getting to the input pin of the transistor or amp chip, measure for power 200VDC range getting to the power input. If you have both present you should be getting AC output to the speakers, unless it's an IC and has a mute circuit in effect.
If you can find a schematic or at least post detailed high resolution pictures it might help. I leave it up to you to decide whether you're capable of safely troubleshooting an open AC mains powered piece of equipment.
