I cant step up voltage
pidja105
Oct 16, 2015
106
Oct 16, 2015
106
Hello,
I taked motor from fan home heater,and small 6000rpm motor
I attach this motors and at output of heater motor which i use as generator get only 0,5v how i can setup this so that can produce 220v?
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
To use a motor as a generator, you will need one with a permanent magnet rotor.
A fan heater motor is likely to be a shaded pole motor with no permanent magnetism and hence no output.
pidja105
Oct 16, 2015
106
Oct 16, 2015
106
It is brushless motor,it has no coil on rotor,if it has not coik or pernament magnet on rotor what it has?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
A brushless motor with PM field should generate.
AC and BLDC motors have three winding's/conductors so should generate 3phase.
Many have a three phase or commutation controller built in, as per PC fans or HVAC ECM motors, in this case you will not see a generated output..
Here is an example 3ph output of a back fed BLDC motor.
M.
  • commutation.pdf
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Sounds like in induction motor but I don't see how it is 6krpm if ran off of 50/60Hz?
M.
davenn
14,261
14,261
OK guys lets hold fire
as I posted elsewhere ....
pidja105, your descriptions are all very unclear.
PLEASE draw a layout of how you expect everything to be connected ... what is powering the motor ( power source)
what is the generator supposed to be powering ?
NOONE else answer till this info is given by the OP
I want to see if this is a pointless thread or it has some merit ??
thanks
PS .... Ohhh and I have just deleted your other thread that was on the same topic as this one
