I can't find any website will tell me what my transformer goes to or is good for
Discussion in 'Power Electronics' started by MSuninformed, Aug 2, 2018.
  1. MSuninformed
    MSuninformed
    Aug 2, 2018
    3
    I have a Retocon direct plug in class two transformer I found in my parents' home after they died. 120V AC 60Hz 5W to 18VDC 150 C. I gather it isn't made anymore.
    What kinds of things would it be good for and in what country?
    Since it isn't made anymore and has been replaced is it safe to use? All areas are undamaged and intact.
    My thanks to anyone who can help.
    #1
  2. MSuninformed
    24,608
    2,490
    A photo might be useful.
    Is it like this?
    (*steve*), Aug 2, 2018
    #2
  3. MSuninformed
    kellys_eye
    Jun 25, 2010
    3,961
    1,057
    West Coast, Scotland
    A transformer like yours is only good for powering something that requires the stated voltage and maximum current.
    If you wanted to experiment you could use it as a DC source to a regulating circuit to get 'any' voltage (within defined limits) from the output.
    kellys_eye, Aug 2, 2018
    #3
    darren adcock likes this.
  4. MSuninformed
    Audioguru
    Sep 24, 2016
    2,304
    509
    18V at 5W is a current of 278mA. I do not know anything that uses 18VDC. It is cheap and is not worth adding a regulator to reduce its voltage.
    Audioguru, Aug 2, 2018
    #4
  5. MSuninformed
    kellys_eye
    Jun 25, 2010
    3,961
    1,057
    Sounds like an old modem supply.
    #5
  6. MSuninformed
    MSuninformed
    Aug 2, 2018
    3
    Yes it is but the face plate is a metallic gold color. On reviewing some replies I have to say Nickle
    words please. No quarters
    MSuninformed, Aug 10, 2018
    #6
  7. MSuninformed
    MSuninformed
    Aug 2, 2018
    3
    So.....toss it?
    #7
  8. MSuninformed
    darren adcock
    Sep 26, 2016
    382
    28
    do you have a way to test it?
    if so and is working....
    do you have a need/use for it? as K.E says above " A transformer like yours is only good for powering something that requires the stated voltage and maximum current.
    If you wanted to experiment you could use it as a DC source to a regulating circuit to get 'any' voltage (within defined limits) from the output."
    darren adcock, Aug 10, 2018
    #8
