HP/Agilent 3325B
P
pfitz
Hi All,
I was wondering if anyone could help me out. In the past I've just been
using this beast as a standard signal generator and that suited me fine
because I didn't have any documentation or instructions on how to create my
own functions on it, and besides I had a Stanford Research DS345 Function
Generator for creating these.
The limitation of this however was that it could only generate functions up
to 10Mhz, and for the most part up to now that has been ok, but now in a
system I'm designing I need to be able to generate a frequency of 20Mhz. All
I want to do essentially, is generate a 50% duty cycle square waveform @20
MHz and vary the rise and fall times, Is this possible with the 3325B?
I've tried contacting Agilent but they say the manual is out of production
and they don't have a pdf.
If anyone knows anything about this I'd appreciate it if they'd contact me
on the email given without the nospam.
regards
pfitz
W
Winfield Hill
pfitz wrote...
According to the HP data sheet, the range is sine waves to 21MHz,
square-waves, triangles and ramps to 11MHz. The square-wave rise
time is 20ns.
- Win
whill_at_picovolt-dot-com (use hill_at_rowland-dot-org for now)
C
CFoley1064
Subject: HP/Agilent 3325B
Date: 4/30/2004 9:50 AM Central Standard Time
Message-id: <[email protected]>
Hi All,
http://www.manualsplus.com/
$35.00 USD in good condition, not including FedEx shipping costs.
Good Luck
Chris
D
Dejan Durdenic
regards
pfitz
No, HP3325A cannot vary rise/fall times of squarewave output and anyway
cannot
generate more than 11MHz squarevawe at all...It has some powerfull sweep
functions,
but it's essentially classic function generator.
- Dejan
P
pfitz
The frequency has to be pretty stable for my app ~ 0.4ppm, Are there any
others out there that might fit the bill?
K
Kevin Carney
HP 8082A pulse gen can do that. The frequency is not real accurate as it
uses a potentiometer to set the rate. It does have controls that will vary
the rise and fall time. They made a few generators like that but not real
solid on the frequency. Check out Tucker Electronics, Test Equipment
Connection, or any other used equipment company
change .combo to .com for correct email
"We ought always to know precisely why a given job
is done in a particular way, and why it is done at
all, and why it can't be done more efficiently,
if it must be done at all."-- T.J.Watson
