I have a double-sided pcb with plated-through holes occupied by component legs. I removed a dead 16-pin DIL IC by chopping off its legs, then unsoldered the legs individually. Use of a solder sucker and solder wick has failed to clear the vacated holes. Any suggestions how to clear them so that I can insert a new IC? (I don't have an iron with the tip shape or heat capacity to solder 8 legs at a time, and I'm reluctant to drill out the solder).
Categories
Platforms
Content
