how to prevent simple AA battery electromagnet short circuit/overheating
shannon
Jan 5, 2017
7
Jan 5, 2017
7
hello ...
when I search youtube for "how to make electro magnet" I see the results as posted in the attached picture:
All the video thumbnails show the same basic thing: a battery with wire going from one end to the other ... the batteries are 1.5V or 9V ... the videos usually mention that the battery will get hot.
My Questions:
1) - is this a short circuit (ie a AA battery with a wire going from one end to the other)?
2) - would this simple experiment be Dangerous if using a much larger battery, say 10*9V=90V?
3) - if 1) and 2) are "yes", then how to protect circuit (and person) from danger?
davenn
14,260
14,260
1) - is this a short circuit?
close to .... how many turns of what gauge wire ??
would be worse MUCH worse
you build something safer
for an electro magnet ................. many 100's of turns of 26 - 30 swg (awg) wire
davenn
14,260
14,260
suppose Scenario A: 0 turns
I didn't want scenarios
You posted a electro-magnet project .... I wanted to know how many turns of what gauge wire was stated ?
shannon
Jan 5, 2017
7
Jan 5, 2017
7
Davenn, you mentioned
I suppose what I am hoping for is a suggestion on some simple, common, basic electronic component that I can put in the circuit (whether it is a 9V DC or a 90V DC circuit, with 0 turns or more) and feel confident that the battery will not be improperly affected (such as overheating or blowing up).
Is there some component that I put into the circuit to know that it is a safe simple circuit?
thanks, Shannon
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Well, you could use a fuse.
The alternative is a resistor, but you will need to learn how to calculate an appropriate value. In addition this will pretty much render the the device useless as an electromagnet.
The "appropriate" resistor will vary with the resistance of your coil, the battery voltage, the maximum safe current through the wire, and the maximum safe current from the battery.
The general solution is to increase the number of turns and/or reduce the size of the wire to increase the resistance of the coil itself to make it appropriate to connect to a particular per source.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Instead of adding a component that tells you the circuit is safe, why not design it to be safe and use common sense?
Simply do not use a little AA cell or little 9V battery to drive the starter motor (it is an electromagnet) in your car.
7,682
7,682
You make it safe by determining the maximum safe current from the battery, determining the resistance that will result in that current, then making the wire long enough to have that resistance.
For an AA cell, that is about 1A at which the battery will last about 1 hour.
To get 1A you need a resistance of 1.5Ω (for a single 1.5V cell)
#28 wire is the smallest you would use to carry 1A. It has 64.9mΩ per meter, so 1500/64.9 = 23m
So, to make an electromagnet running off 1 AA cell without overheating the battery you would wind 23 meters of #28 wire.
